need info on choosing a rototiller
   / need info on choosing a rototiller #71
hey guys, a friend of mine is thinking of buying a tractor mounted rototiller for his tractor and is needing some info before buying one. He has a older 601 ford tractor. i think its about 35 or 40 horse. What are some of the features to look for in a rototiller and which brand seems to give you the most bang for the buck.
Late entry, but in the spirit of the OP.... I have a Landpride rtr1558 reverse tiller that I have used with a Kubota L3940 for the past 3 seasons now and I am totally pleased with it. It wasn't the cheapest, but I have been breaking land that was all grown up and wooded when I moved here and it has performed flawlessly. It has a slip clutch, which has been tested a few times by things I missed while root ripping.
With a minimum of care I believe it should last as long as I want to garden!
   / need info on choosing a rototiller #72
I've got the KK II TG60 rototiller on my Kubota and it works just fine. I was concerned that my tractor was a little underpowered for it, but it handles it just fine. Right now I work it in the Florida sand, but I plan on trying it out in the Texas clay next year.
The only critique I have is the paint. When I got it, it was rusting under the paint in spot, but a wire brush and a rattle can fixed that pretty quick.
I'd buy one again without any hesitation.
What is the difference between a KK I and a KK II?
   / need info on choosing a rototiller #73
Would a 60" tiller be the right size for my John Deere 2520? I've got a 60" box blade ..and it does OK with that, but,of course its not PTO driven
   / need info on choosing a rototiller #74
Hey no problem its a good product! My shaft and slip clutch has made in china all over it there isn't any doubt mine is the exception which is just my luck.
They work fine I am not knocking them yet just am taken back by the 99.9% made in USA statement you made.
And btw since you are a mouthpiece for KK.... I have a very slight gear box leak at the inside of the tine shaft since brand new that my dealer (Orchlens) couldn't fix because they are not a service center.
why they sell things like this I don't know but that's beside the point)
I told them I could fix it but wasn't doing it for free I have 200 other projects at any one time so KK sent them the seals and said they would pay me $50.
I haven't had time to mess with it but what do you think about how I have been treated is that a fair deal? (my shop rate is $70 per hour so would be working at slave labor rates to fix something that imo should be under a warranty of some kind just my 2c)
A very slight gearbox leak is not worth fixing. Mines been leaking since the 2nd time I used it in 2006. So far Im down about an ounce. I would venture that all units will show some seepage. The only way to avoid is replace the seal and park it.
larry
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
2001 Dodge Ram 3500 4X4 Flatbed Truck, VIN # 1B7MF33651J565664 (A54865)
2001 Dodge Ram...
Harrell 3605 (A50123)
Toro Sand Pro 5020 (A53316)
Toro Sand Pro 5020...
Ford Pickup NR (A50323)
Ford Pickup NR...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
