Need info on self priming pressure washers
   / Need info on self priming pressure washers #1
fisheye
Kincardine, Ontario
Kubota MX5000
I need to wash the mud from my Kubota tractor and backhoe so I can grease it properly. Where I am using it has no electrical power or pressurized water supplies. I was hoping to purchase a gasoline powered pressure washer that can take suction out of a pond. I am hoping to hear from someone with experience in this who can recommend a manufacturer and model and give me tips on use.
   / Need info on self priming pressure washers #2
I had the same issue. I would recommend using a standard pressure washer and a water tank in a pickup truck bed. I also collect rainwater from my barn roof into a 300 gal. cistern and draw water out of it with my pressure washer . I seriously doubt you'll find one that can draw water from a pond and lift that water. Guess you could build a platform, place a plastic water tank or a tote on it, pump water into it with a pump, then simply attach your pressure washer to it, and let gravity help the water flow. But a 100 gallon water tank from Tractor Supply and a regular pressure washer would be all you need.
   / Need info on self priming pressure washers #3
I tend to agree. Additionally, I would think that at some point, even if were able to find a pressure washer that would self prime, you would have to deal with filtration at the intake end. I have a tendency to think that pressure washers likely don't enjoy running material through their innards.
If the 100ga tank suggestion HCJtractor suggested is too large/expensive you could also use a 50ga poly-barrel or olive barrel. It would be a relatively simple to purchase bulk head fittings and rig up a gravity feed from the tank to the pressure washer.
   / Need info on self priming pressure washers #4
I wear out a pressure a year so you can take my advice or not since I go thru them so fast;)
The only ones I have that self prime reliably are the cat pumps, put a foot valve at the bottom of the suction line with window screen around the foot valve and you keep most of the crap out.
Since I go threw them so quick I can't justify the extra expense of a cat pump, I just buy the cheapos and hook a 12 volt bilge pump(also screen covered) to the bottom of the suction line and never have a problem with prime.
   / Need info on self priming pressure washers #5
I used a 300 gallon tote on my trailer. The head pressure is enough to prime the pump. Don't get a cheap water hose from the tank to the PW or it'll collapse. Probably be good to have some potable water out there so get a food grade tote and clean it out.
Brett
Thanks for all the suggestions guys. I'm kind of intrigued by the suggestion of using a 12 V bilge pump to provide positive suction to a standard gas powered pressure washer. I did read a advertisement that Karcher Pressure Washers are self priming but couldn't find any information as to how high they would lift the water. I guess it wouldn't be a huge deal to set up a head tank and fill it to provide suction to a washer.
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
KBH 25 TON TENDER (A56438)
KBH 25 TON TENDER...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
Sterling AT (A56436)
