Need opinions on future tractor purchase.
   / Need opinions on future tractor purchase. #81
Yes there is a HUGE difference in build quality and performance commercial vs low end residential zero turns.
I've been putting these things together for delivery all summer at a tractor and implement dealership. Exmark, Gravely, Toro. There is a marked difference between their commercial and residential items. Just how they connect their baggers between the two let alone build integrity, is also differentiated
   / Need opinions on future tractor purchase. #82
I owned a 3038E for 5 years on 16 acres with about 10 in open pasture. The HST is great and I was never short on power for running a 5’ bush hog. It never once failed to start or gave me any issues.
Here’s the downside and why I traded it in for a larger machine. The weight is awful, if you don’t load the tires it’s very tippy even with the small loader it has. It will not run a 4’ disc without spinning all 4 tires. The power is there but the traction is not.
If your going to mow with it, use the 3 point, and rarely use the loader I would whole heartedly vote for the 3038. If your using it ALOT for the loader and doing ground engagement I would say look elsewhere.
   / Need opinions on future tractor purchase. #83
Bigcut,
Hey fellow, slow down a second. Kukje did NOT purchase Cummins. They did solicit and were awarded the rights to produce limited Cummins Engines for an undisclosed cost. That is a HUGE distinction. Same as CAT, allowed a S Korean firm to produce, NOT Own, Perkins diesel engines.
In today's economic world, Davey does NOT purchase Goliath. Revisiting information from your post # 71.
I stand corrected....So, Cummins is still an independent company ?
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A58214)
2013 XLR...
LOT: Dewalt Electric Sawzall, Craftsman Palm Sander (A59076)
LOT: Dewalt...
2015 UTILITY VS2RA 53FT REEFER TRAILER (A58018)
2015 UTILITY VS2RA...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2013 Chevrolet...
1992 DFI PULL SPREADER (A58375)
1992 DFI PULL...
Auger Drill Bit (A56857)
Auger Drill Bit...
