Need SCAG Turf Tiger HELP
/ Need SCAG Turf Tiger HELP #1
wadej
My Scag has a 29 hp Kawasaki EFI engine. I've replaced fuel pump, filter and battery. Mower starts up runs great better than it ever has, as soon as I engage the blades the mower stops dead in it's tracks. Then mower is very hard to restart, can anyone help?
/ Need SCAG Turf Tiger HELP #3
I also don't know very much about Scag equipment, but this sounds like a safety interlock problem.
From the Scag owner's manual on page 11:
"The mower is equipped with a safety interlock system
that prevents the engine from starting unless the deck
drive is disengaged, the parking brake is engaged, the
steering control levers are in the neutral position and the
operator is in the seat. The interlock system shuts off
the engine if the operator leaves the seat with the steering
control levers not in the neutral position and/or the cutter
blades engaged and the parking brake not engaged."
There is a contradiction here when the manual says the machine won't start unless the operator is in the seat. Have you been able to start the machine while not in the seat in the past? Most mowers have two safety circuits; one to disable the starter and another to kill the ignition after the motor is running. Most allow the motor to start without being in the operators seat if the parking brake is set.
Here's the manual and the wiring diagram:
http://www.scag.com/OpManuals/STT/2003STTIPL/2003STTIPLcomplete06082.pdf
http://www.scag.com/OpManuals/STT/2003STTOPMAN/2003STTOPMANcomplete03120.pdf
/ Need SCAG Turf Tiger HELP #4
If it's not a saftey switch then check the deck for operation, see if the blades turn and not locked up for any reason.
/ Need SCAG Turf Tiger HELP #5
describe hard to start: wont turn over, turns over but will not start etc .
2018 Yamaha VX1050B-TA Waverunner Jet Ski (A59231)
2018 Yamaha...
2017 KOMATSU PC360LC-11 EXCAVATOR (A60429)
2017 KOMATSU...
9ft. Flatbed Truck Body with Gooseneck Connection (A59230)
9ft. Flatbed Truck...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
FUEL CELL (A58214)
FUEL CELL (A58214)
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
