Need some help picking an solenoid valve
   / Need some help picking an solenoid valve #1
Cord
Veteran Member
Richfield, Wi
Resident Architect
I'm looking to add a second accessory port to my skidsteer. I currently have one circuit that is controlled by a manual valve and I want to split it's flow. To do this, I'd like to add a solenoid selector valve that let me choose between the two circuits. For example, port A is active when the valve is off. Port B is active when the valve is on. I do not need to split the flow between the two ports at the same time. I do not need a relief and I believe I want a closed center valve. There are lots of posts on this forum for people adding a third function to their loader; the problem is flow. Your loader circuits are pretty low flow so a 10gpm valve is sufficient. Well, my pump is rated for 31gpm so I need a valve that is listed for not less than 24gpm and more certainly wouldn't hurt. I've been unlucky finding the correct valve on Fremont or Surplus Center sites. Any other suggestions?
   / Need some help picking an solenoid valve #4
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52128)
2019 Tico Yard...
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2003 INTERNATIONAL 4300 BOX TRUCK (A51219)
2003 INTERNATIONAL...
2011 Nissan Maxima Sedan (A50324)
2011 Nissan Maxima...
