Need some help picking an solenoid valve
   / Need some help picking an solenoid valve #1
Cord
Richfield, Wi
Resident Architect
I'm looking to add a second accessory port to my skidsteer. I currently have one circuit that is controlled by a manual valve and I want to split it's flow. To do this, I'd like to add a solenoid selector valve that let me choose between the two circuits. For example, port A is active when the valve is off. Port B is active when the valve is on. I do not need to split the flow between the two ports at the same time. I do not need a relief and I believe I want a closed center valve. There are lots of posts on this forum for people adding a third function to their loader; the problem is flow. Your loader circuits are pretty low flow so a 10gpm valve is sufficient. Well, my pump is rated for 31gpm so I need a valve that is listed for not less than 24gpm and more certainly wouldn't hurt. I've been unlucky finding the correct valve on Fremont or Surplus Center sites. Any other suggestions?
   / Need some help picking an solenoid valve #4
2013 MAXX-D BUMPER PULL TRAILER (A58214)
2013 MAXX-D BUMPER...
2005 MERCEDES CLK 500 COUPE (A60430)
2005 MERCEDES CLK...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
