Need some help!
/ Need some help! #1
BriansViper
Dorothy N.J
Kubota B-7800
I have a b7800 Kubota and installing a quick attachment on the bucket. Installing it on the tractor was know problem but the bucket is a different story. I cut off the pins attachment on the bucket. My question is how do I determine the height of the plate?
/ Need some help!
Well, the welder is coming out in the morning. What I can up with is the bucket plate is about 1" above the bucket, seems like any lower the bottom of the plate will be too low and will hit the ground when I back scrap with the bucket down and curled up.
I hope this is right.
/ Need some help! #4
Everything worked out perfect.
Thank you
Glad to hear you got it worked out, and welcome to TBN. These kinds of things need pictures, they help a bunch.
Don't forget to post pictures of your completed bucket.
set of 4 tractor trailer tires Roadforce (A63689)
set of 4 tractor...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2018 TAKEUCHI TL8 SKID STEER (A64279)
2018 TAKEUCHI TL8...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
iDrive TDS-2010H...
INTERNATIONAL 720 - 6 BOTTOM PLOW (A63291)
INTERNATIONAL 720...
