redrocketship
First off, I have at MX5100 4x4 HST that I bought new in 2013 that currently has 550hrs. The tractor had 0 issues until about 500hrs. I started noticing the trans and hydros making more noise. Around 200hrs, I changed the hydro fluid with kubota UDT2 with new filters.
So after hearing more noise, I changed the fluid again and along with all filters at 513hrs. This did not help the noise, and shortly after, I also started to notice a smell of hydro fluid every now and then when using the tractor. The fluid level is right in the middle of the sight window. I also started the noticed that the tractor started running hotter then it use to.
I have cleaned the radiator with water and compressed air, just to make sure its clear, which is was ( clean it after each use).
As its getting warmer, its running even hotter.
So today before doing some bush-hogging, I removed the thermostat all together to rule out a bad thermostat. There was a weird color on the thermostat. After it dried, it would rub off like a powder. The coolant is factory(I havent changed it) and I see no oil in it.
So while bush-hogging today it was just before the hot mark. It would normally be under the half way mark. I had to let it cool down 3 times just to get the bush-hogging done.
I see no oil in the coolant or coolant in the oil so I dont think its a head gasket. I think something with the hydro's is causing the engine to work haone rder and making it run hot but I dont know for sure.
Does anyone have any ideas of what might be going on?
