OP
BGigHarbor
Thanks, all good advice and appreciated.
One thing you mentioned was working with logs, you are going to for sure want to make sure the FEL bucket is attached with Skid Steer Quick Attach, SSQA.. so that you can take off the bucket and put on either forks or a grapple in a few seconds. Grapple would be best, but you can also move logs around with a little practice with a good set of SSQA forks. The 3940, is a lot more tractor than the economy model L3800. More weight, beefier front axle, the above mentioned telescoping lower links and stabilizers (extremely useful feature) and a 3rd generation Hydrostatic transmission with an industry leading design. If a Kubota is what you want, and if you had to choose between an L3800 and a L3940, well you should buy the L3940 if you can swing it money wise. I would highly recommend a hydrostatic transmission especially for a newbie.. I am not a newbie, 5 tractors and 20+ years, but I prefer the Hydro also. You may note I am a Kioti owner, and the Kioti DK40se is comparable to the Kubota Grand L at a much lower price point, the only big difference I can note is the Kubota hydro tranny is superior. Good luck on your hunt, and keep coming back here and asking questions. We will be very happy to spend your money
James K0UA
I search youtube and saw vids of a grapple. Is that aftermarket? And are the forks aftermarket too?
Any disadvantage to the SSQA, ie is it as strong?
All implements are aftermarket as far as I know.. None of the Tractor manufactures make implements that I know of. they paint and put labels on some of them. I am not certain about John Deere's Frontier line of implements, they may make them. SSQA is used on skid steers and large tractors, Both are much stronger than any CUT you would be considering. I am considering the Everything Attachments new wicked grapple.
Day 2 of Compact Utility Root Grapple - YouTube
Everything Attachments Compact Utility Root Grapple 50"
James K0UA
I think I'd get a lot of use out of a grapple on the new property. I'll do some more searching, but that everything attachments small grapple looks slick.
Can most brands of tractors (ie Kubota) be ordered with the necessary hydraulics to run implements like a grapple jaw? Is that a better way to go than adding the hydraulics afterwards?
