greg_g
Super Member
- Joined
- Dec 18, 2003
- Messages
- 6,126
- Location
- Western Kentucky
- Tractor
- JD3720 Cab, 300X loader with 4-in-1 bucket
If it happens when you push the brake pedals down hard, you may be pinching something - but I doubt it. The underfloor wiring is somewhat protected inside plastic looms. You'd likely find a whole loom crushed, then have to open it to find exposed copper. But if it happens as soon as you press on the pedals lightly, it's probably a damaged brake switch. One of these (Switch JK514 - JK514) will work.When I depress the brake pedal the gauges go nuts.
Get under the floorboard and inspect the switch for signs of damage. Then disconnect it at the connector. See what happens to the instrument clusterl with the switch disconnected. Another thing you can try - with the switch still disconnected - is jumper the connector where the switch plugs into the wiring harness. Turning on the key with the jumper in place should illuminate the brake lights. If that doesn't interfere with the instruments, you've proved the problem is the brake switch. If the problem persists, you've got a short somewhere else.
//greg//
