Need to Trench Internet Cable in......Any Ideas?
   / Need to Trench Internet Cable in......Any Ideas? #21
Why not use something like a Nanostation5? I did nearly the same thing as you want to do. Cost about 120 bucks for two and took about an hour to install. No digging, works like a charm. You need a clear line of sight, though.
   / Need to Trench Internet Cable in......Any Ideas? #22
My handyman has my middle buster right now to lay that black poly pipe with. I think he took the bigger plow off and put a sub-soiler point on in it's place. As long as you had a spool so the cable doesn't bind up, it should be an easy job.
   / Need to Trench Internet Cable in......Any Ideas? #23
This is okay for some applications, but having used DDWRT before, there are certainly some down-sides. I don't know about you, but I had to reboot my DDWRT every now and then. And the directional antennas on the radios extend range significantly over a typical router. For the most part, these bridges are set-it-and-forget-it, but they sure do cost a bit more than an old router that you had sitting around anyway.
I have to unplug the router after a power outage and a few times throughout the week. I thought it was the router but I guess it is the firmware. I have been wanting to upgrade the router anyway, maybe I should do it sooner. I have also been thinking about changing my ISP.
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Yanmar YT359 (A53317)
TEST YOUR BID BUTTON! (A52709)
TEST YOUR BID...
2017 Ditch Witch FX50 T22S Towable Vacuum Excavator (A55973)
2017 Ditch Witch...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
