Need vapor barrer in pole barn?
   / Need vapor barrer in pole barn? #22
I used closed cell spray foam on the inside of my metal wall pole barn. I added R-19 batts on top of that, with OSB interior walls. The spray foam works great as a vapor barrier. It also seals all the joints air tight.
   / Need vapor barrer in pole barn? #23
Its the water vapour in the warm interior air that is going to condense when it hits the cold metal surfaces. You have to keep that moisture out of the batts or it will condense on the inside of the cold outer walls and soak your batts, corrode/rust your steel and rot any wood within the fiberglass. If your area is cold enough to get foggy days or frosty nights then you need a vapour barrier.
Google the fiberglass insulation companies such as Dow for details...Neither OSB, plywood, nor drywall will stop water vapour transferring thru to the fiberglass..You need 6mil plastic and sealed joints.
2017 Jeep Patriot 4x4 SUV (A53424)
2017 Jeep Patriot...
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A51406)
2018 VOLVO SD75B...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
