Needing to have logs sawn to lumber
   / Needing to have logs sawn to lumber #1
Paddy
Veteran Member
Bloomington, IN
Kubota, G5200, KAMA 454
I'm in the process of selling our home on 20+ ac. As a departure move, I've planned on cutting a few select trees. The lumber will be used as trim/furniture in the new home. The big one, a 35" dia Cherry came down first. This is a crazy big tree. It is 35' to the first branch. At that point it is a perfect "crotch". It is 29" dia at 35'!! The bottom has some rot, but common in old Cherry. I hope the rot is in the first 5', but I'll see...
I have several 20+ dia Walnuts and several 16-18" dia walnuts. So a good pile of saw logs. I may select a few others
What is the going rate in your areas to have lumber sawn these days? I think most of it will be cut to 1x8s. The crotch I'd like to have sawn special if I can.
Patrick T
   / Needing to have logs sawn to lumber #2
Buckets of grapes!! What a nice parting gift!! Sounds like it will be some beautiful wood to work with.
   / Needing to have logs sawn to lumber #3
Rates will vary for custom sawing. Some charge by the hour others by log scale and some tally the sawn boards. The fairest to the log owner is to pay by the board foot for what comes off the mill. As far as rot goes just remember as long as a board holds together it doesn't make any difference to the sawyer if the wood board is solid or not.
Paying by the hour is the least attractive for the log owner, I can work slower for more money. Paying by log scale is a bit tricky. A good man on a saw mill should be able to beat scaled volumes some of the time. Allowing for defects and sweep or crook in a log takes a skilled person and the scaler is generally going to see a log one way if he is selling it and another way if he is selling it. You may not agree on the percent of defect.
When I customed sawed a few years ago I would get $0.25 per board foot for hardwood or $250.00 per thousand board feet. There may be a set-up or transportation fee with the price of fuel these days.
Sounds like you should get some nice material out of those logs. Make sure you stick them properly and get them air drying right off to avoid mold.
Randy
   / Needing to have logs sawn to lumber #4
If you have any Amish in your area check with them, around here they get 15 cents per board foot for sawing.
I finally got the Cherry dragged out of the woods. Not an easy task even with my 45Hp 4x4 tractor. I had to cut about 4' off the but log to remove most of the rotten center. I'm glad that was as far as it went. I did get a price from a friend of a friend, $65/hr. He is a carpenter by day. Not sure if the price is good but, with out knowing how fast he can cut....The $65/hr compared to 25 cents a bd-ft, is 260 bd-ft/hr.
I will have a lot of work moving, sticking and stacking. I plan to weight down the stacks with concrete blocks to keep it all flat.
How long can the logs sit before I have them cut? I have applied a coat of paint to the log ends to slow the drying and checking.
See photos. The Cherry shot has a 25' tape measure at the bottom for size ref.
Patrick T
   / Needing to have logs sawn to lumber #6
Paddy,
You might want to contact a portable saw mill company like wood mizer, Wood-Mizer Portable Sawmills to see if they have a list of people who have bought their mills n your area. I could have sworn they had a list online years ago but I just looked and could not find it.
There is another website regarding forresty and wood mills which I also can't find. I'm a member but I cant find the book mark. They could answer your questions if a TBNer can give us the link.
Later,
Dan
   / Needing to have logs sawn to lumber #7
Paddy, you really shouldn't try to cut those few logs, just too bad you are so far away as I would have you drop them by my place for keeping.
You might try going to one fo the wood working forums and see if someone in your area might know of a mill that would help you out.
WoodNet Forums: Viewing list of forums
http://www.forestryforum.com/
WoodCentral Messageboards & Sightings
You might have to join the forum / site to be able to post a message, but most of them are pretty good old boys and I am sure if there is someone in the area they will have information for you.
Wayne
   / Needing to have logs sawn to lumber #8
Try to find someone who can quarter saw it for you.
Not the highest yield, not the lowest price, but the best wood.
Awww, anyone with a band mill will SAY they can get the most quarter and near quarter wood possible, but unless they're halving, quartering and then using wedges or a tilt bed... it ain't happenin'
Dan,
That "wood" be great. If the $65/hr is standard and or fair, I'll keep with the friend of a friend. I have some nice walnut and cherry crotches I'd like custom cut and not looking for a guy that wants to hurry past that part. But I do need to look at the big picture, it's gong to cost a few bucks to get this pile cut to lumber..
Patrick T
Wayne,
The pile is growing. In the photos, there is one Cherry and one walnut. I have 4 more walnuts to drag up and the Cherry had 2 branches. Those branches were 12' long and about 20" dia. Beyound that there are several decent 12" dia Cherry logs.
Patrick T
Reg,
You are right, getting true quartering is difficult.
I don't think Cherry and Walnut quarter that well. Oak is the clasic to quarter due to the large medular(sp) rays, the tiger stipe effect. Beach has them but they are real fine. Cherry some but again small. Walnut and Cherry are famus for the burl like mess that forms in the crotches, fine gun stocks.
I hope to get the big crotch special cut, 5' long. It is 29" at the base and has 2 20" dia sisters coming off. I'd like to get 4 good book matched slabs for a large table.
More photos as I get them dragged up. Now back to packing, I have to vacate to 29 days after 27 years!
Patrick T
   / Needing to have logs sawn to lumber #12
Patrick T
This is my 2 cents worth, I cleared a lot a few months ago and It was nice pine logs and I plan to build another shop, I decided to have the logs sawed. I have a local guy that saws for us, I have never carried that much to him before, the mistake I made was I should have gotten a firm price, but he had never stuck it to me before. A pile of logs, that I thought would cost $4-500, cost $1000. I really think, I could have bought the same amount from Lowes, for about the same price and wouldnt have to pay to transport and handle the lumber, plus it took him about 6 weeks to saw it and some of logs looked bad.
Sooo get a firm price, before you dive in. A professional sawer, knows how long it will take and what to charge
   / Needing to have logs sawn to lumber #13
Not to spoil your fun, but it doesn't take very long for cut ends to start drying out and stress creation to start.
Then sawing can become a problem, in some cases a DANGEROUS one.
The IDEAL would have been to have a sawyer lined up and start sawing the day they come down.
Second best; PLEASE coat those cut ends.
Anchor seal is probably worth the cost for what you have, but even a cheap oil based paint would help.
...and of course get 'em properly stacked and stickered straight away so you KEEP the value, but you didn't need me to tell you that (-:
   / Needing to have logs sawn to lumber #14
To answer your question as to how long logs can set before being cut.
Keep them off the ground and in a dry location out of direct sun as much as possible. You want good air circulation around the logs on all sides. I have milled an oak log that was seven years old and the wood looked good. There was some white pine that was under water for many years that was nice and soild with little staining.
Given the right conditions your logs should hold up well for quite a while. Most of the time the outside wood which would be affected becomes a slab which is discarded.
As far as sources for saw mills your local Extension service may list people who could help you.
Randy
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2019 Ford F-150...
SHOP TOOLS (A58214)
SHOP TOOLS (A58214)
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Dodge 5500 Bucket Truck 4WD (A61306)
2018 Dodge 5500...
