Neighbors tractor broke from towing up hill ?
   / Neighbors tractor broke from towing up hill ? #11
You pulled it from the back , correct ? If it was in gear , the only gear it could have been in was reverse . If clutch was not disengaged it would pull very hard or drag wheels . If it was in gear with clutch disengaged , the transmission and the gear it is in is out of the picture . Sounds like pilot bearing or pressure plate as mentioned . That 20 series utility tractor is one of JD's biggest flops . I don't know where this other theory comes from , but I need to read that book .
   / Neighbors tractor broke from towing up hill ? #12
Hard to say exactly what happened for sure. One thing for sure, if it was really in neutral, nothing could have happened to the clutch while towing. Maybe he didn't really have it in neutral. How fast did you tow it? If in a low gear and the clutch is held in, the disk spins extremely fast and can disintegrate due to the excess centrfugal force. To make it simple, let's say that in 1st gear, the tractor travels at 1 mph at 2000 engine rpm. If you tow it in 1st gear at 10 mph, the clutch disk will spin at 20,000 rpm. It will definitely fly apart. The same thing can happen if you drift while in a low gear. Lets say you are in low gear going up a steep hill or embankment and then push in the clutch and drift backwards while still in a forward gear. Even if you only drift back at 5 mph for an instant, that can be enough to explode the clutch disk. Seen it happen many times.[/
This should be in the book for safety concerns . I really do not understand your theory but am willing to learn .
   / Neighbors tractor broke from towing up hill ? #13
Kevin, I think jd110 explained it very well. Much better than I. But like him,,,, I have saw this type of failure.
I'm not sure what you meant when you said "If it was in gear with clutch disengaged, the transmission and the gear it is in is out of the picture"?
If the transmission is in any gear, the clutch is disengaged, and the vehicle is moved by pulling, coasting, pushing, whatever, the only thing that is out of the picture is the pressure plate and engine. Everything else, i.e., transmission gears, powertrain, etc., is turning. If the vehicle is moving at a ground speed much faster than the selected gear can normally propell the vehicle then the parts are turning at a much faster rate of speed than designed to endure.
On my rock truck the clutch disc completely exploded. The bellhousing was full of shrapnell and clutch disc pieces. It was ugly, and expensive. A mistake I never made again.
I'm not saying that's what happened to the OPs tractor, I'm just saying I've experienced this destruction.
I sure want to thank everyone for the input, my neighbor had it hauled to the local tractor mechanic this morning and I will post what happened to
it as soon as I know something.
I really feel bad for him and hope the repairs don't get to expensive.
   / Neighbors tractor broke from towing up hill ? #15
Exactly- the clutch disc is splined to the transmission input shaft, so if the transmission is in gear (any gear) the disc WILL spin, at whatever ratio the selected gearing is at...assuming the clutch is depressed, Otherwise the the rear tires would have skidded.
Now if the tractor was not in gear (as stated), the input shaft would be stationary- therefore no effect on the clutch assembly...
So it does not sound as if towing caused the failure , because, as he said- it was not in gear.. sounds like a freak failure, it does happen sometimes.
   / Neighbors tractor broke from towing up hill ? #16
It sure does!!!! Heheheheh.
I talked to my neighbor today and he asked me to take a ride with him to the tractor repair shop, the mechanic had finally split the tractor and removed the
clutch and pressure plate.
Wow, the clutch was fragmented into tiny pieces, I could n;t believe what I was looking at, The mechanic Jack, also showed him the pressure plate
and said he should replace this as well, it has 3 fingers on it with springs that he says are weak.
Jack also told him that it was a odd ball plate and he has not been able to locate one as of yet,
He further stated that J.D. used many different parts in the 1020 series. I will let everyone know what the final cost
is for the parts and repairs.
   / Neighbors tractor broke from towing up hill ? #18
To my knowledge JD offered mainly only 3 different clutch/PP setups. one for dual stage clutch,one for transmission driven pto & one for hyd ind pto. Very rarely did ag tractors have hyd reverser
Tx Jim,
Thank you I will pass it on to the neighbor, By the way, he is thinking of just replacing the clutch, the mechanic said he will do what he wants, but won't
guarantee it.
duke
   / Neighbors tractor broke from towing up hill ? #20
If PP still has good spring tension,gripping face is smooth and fingers aren't worn then current PP will probably be just fine. If you'll post what type pto 2020 has and if it has hyd hi-lo I can post clutch part numbers.
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
2002 VOLVO L150E WHEEL LOADER (A51246)
2002 VOLVO L150E...
2020 Mathieu MC210 Azura Flex Street Sweeper (A51691)
2020 Mathieu MC210...
Cummins Diesel Engine (A51692)
Cummins Diesel...
2019 Ram 1500 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500 4x4...
2007 Ford Ranger Pickup Truck (A51692)
2007 Ford Ranger...
