New 4000 Twenty Series Article Posted
   / New 4000 Twenty Series Article Posted #31
I do wish Deere would post the level of documents that Stoneham's eventually puts up but I'd have to say Deere's site already has more info by far available than any other manufacturer bothers to post.
Stoneham's example doc for 4510-4710
Unfortunately the Stoneham's site doesn't yet have any 4000 Twenty docs posted.
In any case re dimensions - I'd bet you'll need a good tape measure to find any difference's between the 4000 Twentys and 4510-4710 CUTs. The whole back end of the tractor chassis is identical (except for the one magic 3-point housing casting part # I ran across! /forums/images/graemlins/tongue.gif), the wheelbase is identical, the wheels/tires are the same, the seat is identical... you get the picture. The ROPS does use a different part number but it must be a very subtle difference. The fenders/deck are new and differ in tiny details but seem essentially the same size.
   / New 4000 Twenty Series Article Posted #34
OK, _RaT_, you caught me. I was ignoring you. See, I don't like you, and really didn't want to tell you... /forums/images/graemlins/tongue.gif
Actually, I missed your post...
I know this comes as a shock, but OK is pretty much under water. I heard is said that if our longtime Senator Kerr hadn't died, the whole state might be under water... I have heard them say stuff like more shoreline than Kalifornia, or more lakes than Minnesota , as if anybody cared...
From the air it sure looks like a gem field with all the glittering lakes and ponds...
So we get to play on lakes quite a bit But we have too many important things to be getting a SeaDoo, maybe a pontoon boat, though...
   / New 4000 Twenty Series Article Posted #35
Well, I AM slipping.. I missed the specs questions...
Steve is half right. I am NOT a Deere website expert, BUT the specs for loaders and hoes are under the "Build Your Own" Configurator. Click on the Features tab at top. I will try and track down some....
   / New 4000 Twenty Series Article Posted #36
Here is the owner's manual for the 400x Loader
No real specs there! /forums/images/graemlins/confused.gif It may be preliminary...
The backhoe and tractor manuals aren't up, yet
   / New 4000 Twenty Series Article Posted #37
<font color="blue">I am NOT a Deere website expert, BUT the specs for loaders and hoes are under the "Build Your Own" Configurator. Click on the Features tab at top. </font>
How's <font color="green">'Deere Navigation Wizard' </font> sound? /forums/images/graemlins/grin.gif
I went through the 4x10 series and found the tractor spec's but could not locate any FEL spec's. /forums/images/graemlins/confused.gif
Don
   / New 4000 Twenty Series Article Posted #38
Go here and click the Tractors and Attachments bullet. Leave it on Build and Accessorize and then click Continue. Then, in the Attachments for Compact Utility Tractors pull down menu choose the loader you want and click Continue. When the page loads click Features at the top right.
   / New 4000 Twenty Series Article Posted #39
The loader has specs, but, alas I can find none for the backhoe, hence I relinquish my title! /forums/images/graemlins/crazy.gif
400X Loader
Specifications Per ASAE 301.3
Measured @ Pivot Pin:
Lift Capacity 2368 Lbs. (1074 kg)
Lift Height 112.8 In. (2864 mm)
Boom Breakout 3506 Lbf. (15,600 N)
Dump Angle - 46 Degrees
Rollback Angle - 31 Degrees
Quick-Tatch Loading
Quick-Tatch Carrier
Mounting Frame
Hood Guard
Bucket Level Indicator
73 In.(1850 mm) Materials Bucket
   / New 4000 Twenty Series Article Posted #40
"I was ignoring you. See, I don't like you, and really didn't want to tell you... "
I see. So thats how it is. OK then. Allrighty. Uh huh, Yada yada yada, thats great, I'll get back to ya. /forums/images/graemlins/grin.gif Rat...
1999 24DTA pintle hitch trailer (A52748)
1999 24DTA pintle...
2010 Nissan Sentra Sedan (A51694)
2010 Nissan Sentra...
2023 JOHN DEERE 2032R LOT NUMBER 164 (A53084)
2023 JOHN DEERE...
378813 (A51573)
378813 (A51573)
2024 Bintelli ActivEV Pulse Electric Golf Cart (A51694)
2024 Bintelli...
2007 KENWORTH T600 (A52472)
2007 KENWORTH T600...
