That's quite a shopping list you've compiled! Nearly everything needed for a commercial landscaper! :thumbsup:
With the wider tires and the additional weight you should have no problem with a 92" box blade. Given that configuration and the hyd top link - on the fly adjustments should be a thing of beauty!
I am planning to do quite a bit of landscaping, trail/unimproved road building, and garden development on my farm. I think that after many years of juggling too many things, I am finally getting it down to a more manageable load, so this will actually be possible. This reminds me, the one implement that I haven't added to my shopping list is a tiller. I am still thinking about your Frontier 1207, I believe it is. I have had some conversations with some of my farmer friends that are very serious about their vegetable gardens (these are small scale commercial gardens) and they have recommended that I look for a used small (25 or so hp.) tractor to run a small tiller, no larger than 4'. The gardens that I plan, cumulatively, would not exceed about three acres, and more than likely not more two acres. My friend's idea was that in small one acre deer fenced gardens the 5085M would not be ideal.
Any more thoughts about adding the hydraulic side link? I guess I could always do it later, if I felt the need.
Is that model of chain harrow one that can be re-configured or expanded by adding sections? If so, sounds good to me... My only reservations would be sufficient width to do the work efficiently. You should have more than enough tractor to pull a larger unit. Storage could be a simpler problem to address than an implement that doesn't do the job!
I will be talking with my dealer later today and will ask him if this chain harrow can be expanded. If not, maybe I will go for the 11' or 12' model. I had also thought that this tool might have been useful for maintaining unimproved dirt road / trails on my farm. If it is any wider than 9', it just wouldn't work for this purpose.
Like the addition of the offset feature with the flail. And the hydralic angle on the landscape rake should be a sweet feature as well. You'll be able to "windrow" sticks and debris similar to what a harley rake would do.
I think that this is a very nice flail. I would like to go with an 8' of the same unit, but my dealer tells me that it is not recommended at my hp. I have a hard time understanding this, but I think it is because this unit is often used in orchards to grind up the the cut limbs after pruning. I believe it is rated to grind up 3" material and weighs over 2200 lbs. I know that you have the York rake and that York was the original manufacturer, but this LR800 looks pretty good and is substantially less expensive. I have only seen it in the catalog, but my Woods 720 Brushbull is built very tough.
Gonna need a higher resolution digital camera for all those pics now!
AKfish
I will post some pictures, but this has been a pretty slow process, and I am currently out of town on some business.
Thank you again for all of your suggestions,
Island Farmer
