New b2910 Implements and Question?
   / New b2910 Implements and Question? #11
Henro:
After a hard days work the worker should surely have at least several cold ones!! /forums/images/graemlins/smile.gif
Egon
   / New b2910 Implements and Question? #12
Hi Bill,
I've moved stuff similar to that and I think a couple of things can happen that hamper the loader's ability to lift it. One, stuff that is wet can create a "suction" of sorts between the bottom of the bucket and the material, this suction resists the lifting force. Two, taking "too big of a bite" and the bucket is "over-heaped" if you will. In the very few instances I've observed this, the loader had no problem with the material after a.) it was out of the material (suction broken) and/or b.) excess "heap" was "curled off" (it would've fallen off by itself as I traversed the yard...might as well leave it in the pile).
Compounding the above issues is I've found myself trying to lift the bucket AND curl at the same time, and as the diagram shows on the loader, this isn't a recommended operation as lifting force is greatly reduced.
Now, of course, it always is possible that your stuff is heavier in PA than up here in MA. /forums/images/graemlins/grin.gif
Anyway you slice it, it's light years ahead of using a shovel. /forums/images/graemlins/laugh.gif
~Rick
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
2016 John Deere 17 Mini Excavator (A47477)
2016 John Deere 17...
Freightliner Tender Truck - Adams Tender (A55301)
Freightliner...
7021 (A50322)
7021 (A50322)
