New Battery for TN
   / New Battery for TN
Soundguy said:
Wow.. i had a different take... I figured in front of the radiator it may get hot.. also.. if it leaked.. it had a nice paper thin radiator with which to leak on.. vs a cast iron head. CG...
Soundguy
I understand. I will have to look at the heat issue. Mine is about 6-8 inches from the radiator. The air flow is across the battery towards the radiator, so at least air flow is in the right direction. Now, radiant heat is another issue. I wonder if the air flow overcomes the radiant heat issue???
Bob
   / New Battery for TN #22
Chris, from my experience, the TN battery is a much better location for being able to work on it. The older Ford 4000 and 4500 TLB that we still have has the battery on top the motor and it is a pain to access with the loaders on them. The TN has it in front and makes it easy to get to, just pop the hood and your there. The 7710-II has it below the right side cab door and it swings out but you have to remove the top step (just pops off). There is a latch you have to undo first also, then take the cover off to access the battery, the TN is still a lot faster to access then any other of the tractors I use.
As for heating from the radiator, it has never been a problem. In fact I have never had any problems with the batteries on any of my tractors other then the 6 volt jobbers kicking off every couple years and needing replaced.
2019 FORD E350 16FT BOX TRUCK (A59575)
2019 FORD E350...
2014 KOMATSU D51PXi-22 CRAWLER DOZER (A52709)
2014 KOMATSU...
1969 MERCURY MOTOR AND STAND (A58374)
1969 MERCURY MOTOR...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
2021 Honda Pioneer 4x4 Utility Cart (A56857)
2021 Honda Pioneer...
12V Diesel Fuel Transfer Pump (New/Unused) (A59225)
12V Diesel Fuel...
