New BX23-3ph will not raise after newly installed
   / New BX23-3ph will not raise after newly installed
Final Update.
It took the mechanic about an hour but he found the problem. The control lever for the 3ph mounts to another bracket under the fender. It is here where the 2 parts are joined by 2 bolts where the problem was found. The factory assembeled the lever to the the bracket without lining them straight and as a result when the control lever was moved to the lifting position it wasn't able to engage fully because the lever was only able to go as far as the plastic groove on the fender would allow it. He loosened 2 screws and straightened the lever so now it works perfectly /forums/images/graemlins/smile.gif. Simple, minor problem that took some close investigating by the mechanic.
Jerry
   / New BX23-3ph will not raise after newly installed #22
Re: New BX23-3ph will not raise after newly instal
<font color="blue"> </font> "... you have a defective Fetzer valve. Some ball bearings and a few quarts of 30wt should fix it..."
<font color="black"> </font> Get me some Pennzoil ... no, wait. Make that Quaker State. /forums/images/graemlins/laugh.gif
Gotta love Fletch.
PREDATOR VACUUM PUMP (A53843)
PREDATOR VACUUM...
2021 CASE 580SN WT (A47477)
2021 CASE 580SN WT...
2014 MACK GU713 WINCH TRUCK (A53843)
2014 MACK GU713...
2013 DRAGON ROLL OFF TRAILER (A53843)
2013 DRAGON ROLL...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
TMA (A49461)
TMA (A49461)
