New Cab Heater not working well...
   / New Cab Heater not working well... #1
Dave___in___CT
West-Central CT
Kubota L3130, LA723 Loader, BH90 Backhoe, Curtis Cab, || '82 Gravely 8199KT garden tractor
Hi...
Anyone have the 15,000 BTU Tuck-Away Hot Water Heater by Curtis Cab ? How well does your's heat ?
I have a new one in a Curtis Cab on a Kubota L3130... dosen't seem to heat all that well...
If it's above 28 F or so... the cab will get to the mid-50 range... this is OK...
But... one night... was 11 F outside... cab only went to 28 F max... then went down to 22 F within an hour while snow plowing... /forums/images/graemlins/frown.gif
Heater hoses seem warm enough... tractor's temp guage read same as when 30 F + outside... even insulated the heater hoses on the outside of the cab...
Tractor only has 1 temp thermostat... so can't change that...
Experiences? Sugestions ?
Dave...
   / New Cab Heater not working well... #2
I have the 15000 btu heater in my Curtis soft side cab on the New Holland TC40D. I was actually rather impressed with the heat output. Its noisy with the fan on high speed but the heat output is pretty good.
It was cold yesterday (windchill around -25). I didn't check the temp inside the cab but I had my insulated coveralls unzipped and stocking cap and gloves off. If I were to guess I would say it was better than 50 degrees.
I haven't insulated the hoses to the heater but will probably do that this weekend. Again, I was pleasantly surprised on the heat output.
   / New Cab Heater not working well... #3
Dave..... it isn't the heater that is the problem it is the cab itself. There is no insulation in a cab and when the weather gets that cold outside, the cab is radiating heat at a faster rate than the heater box can replace it. If you are not satisfied with the amount of heat that the engine produces because of the thermostat, than put a small piece of cardboard in front of the radiator and that will restrict the air flow causing the engine to run a few degrees hotter. This might help the situation, but when the temps drop like they did last week, all heaters become strained to their maximum output. Put on an additional sweater and some insulated underwear and tough it out till better weather arrives in a few months...
   / New Cab Heater not working well... #4
Are you sure the heater hoses are warm enough? I just installed the same heater and the directions that came with it were wrong. I called the dealer to confirm this. The way Curtis had me pipe it got little or no circulation. Make sure the cab is sealed tightly where you mounted it. If it is drawing in outside air, it can only heat it so much. You want to be recirculating the cab air as much as possible. There's enough holes in the cab to make sure you are getting enough fresh air.
Hi...
What is the wrong & right way to hook it up so I can check it...?
This may be it... Air is warm from heater... not hot at all... feed/return hoses warm too...
Cab area... I put self-stick weatherstripping over any extra openings in the tractor's seating area...
And yes.. no insulation in the cab or tractor's sheetmetal... only possibility on cab is the ceiling... but it's a nice lookin' fuzzy material I'd rather not cover up...
Possible to add some to fenders inside... maybe under floor matt...
It's certainly a LOT better in the cab than outside... no wind or snow!
I just expect to be warmer than like 22 F when it's 11 F outside... 30's to mid 50's is fine...
Thanks...
Dave...
   / New Cab Heater not working well... #6
Dave
From what I know of the Curtis heater and from seeing your setup, I think it should be much warmer. If I recall correctly, you told me the tractor was only coming up one marker on the temp guage when it was that cold out. If your heater is hooked up correctly I think the tractor is not coming up to temp. The factory heater in my New Holland TN Cab had the cab above 65 when it was around 5 outside and I didn't have it turned up all the way.
Andy
   / New Cab Heater not working well... #7
Dave,
Once you double check setup to make sure everything is correct, maybe the thermostate should be hotter maybe 180-190 degrees in stead of probable 160 factory spec...
Someone on this board bumped up their thermo- I think its Wildman....he has a JD 2210
The heater should heat that cab up pretty good even in single digit weather....
good luck
Ducati
   / New Cab Heater not working well... #8
Are you sure you don't have an air lock? How high is the heater mounted relative to the water pump? The higher it is the greater the chance of an air lock. I take my cab off every summer so I have quick-disconnects on the heater hoses but even so I get air locks. I can't be bothered trying to bleed the heater hoses every fall so I have an inline fuel pump in the supply side heater hose. This pumps the hot water up to the top of my cab where the heater is mounted and it provides lots of heat even on the coldest days in spite of there being no insulation in the cab.
   / New Cab Heater not working well... #9
The directions that came with mine told me to use an available port on the water pump and gave me a tee fitting to go in the radiator hose. I actually had to use a port in back of the thermostat on the engine block. Their way puts both of the heater hoses on the same side of the water pump so I had no flow. Course this is for a New Holland, yours may be set up different.
   / New Cab Heater not working well... #10
That doesn't look like the new model heaters we've been getting from them. that looks like there old model they used to use. Are the valves open for maximum circulation?
Here's the actual heater... other photo from Curtis site...
Tractor's temp guage goes to 4 marks max... was at 3 or 4 with low heater output...
Thermostat... dealer says only one available for the tractor... don't wanna' change it on a new machine...
Air lock... hmmm... maybe... dealer installed the unit... both hoses are warm next to heater so there's some flow...
Shutoff valve fully open...
<font color="blue">UPDATE....
</font>
Called Curtis yesterday...
Guy says some recent heaters have a severly undersized/restricted inlet defect...
He's sending a new heater core...
Hopfully this is the problem & solution...
Thanks for all your help & suggestions... !
Dave...
   / New Cab Heater not working well... #12
When properly installed we have guys working in there shortsleve shirts in a curtis cab that heater is usually awesome. I think the flow of hot water may be bypassing somewhat causing your cooler temp.,
   / New Cab Heater not working well... #13
Good luck sounds like your problem will be solved shortly.
   / New Cab Heater not working well... #14
</font><font color="blue" class="small">( Called Curtis yesterday...
)</font>
Glad to hear that Curtis is standing behind their product and trying to help you out. Make sure you let us know how it all turns out. /forums/images/graemlins/smirk.gif
Now all you need to do is hope that Curtis doesn't send the replacement heater with the brother of the UPS driver that delivered to Gary in Indiana before Christmas!! /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
   / New Cab Heater not working well... #15
Dave...... Curtis is in Worcester MA and is only about an 1 1/2 hours from you... It would have been worth the trip just to see their operation and you could have exchanged the unit yourself. Guess that it is too late since they have already shipped it to you though.....
I have been thinking of contacting them and doing a "field trip" with the other guys from the CT TBN group..... would be great if we could get a bunch of guys together for this... anyone else interested????
   / New Cab Heater not working well... #16
Junkman
I have been in the Curtis factory several times and it is quite impressive. Robotic welding, powder coating equipment large enough to handle their large plow blades, etc.
Andy
Yeah... Curtis is not far away !
Hopefully the new core will be here before the weekend...
I hope the current heater core IS DEFECTIVE so the issue will be put to bed... and I have to open a cab window to stay cool... /forums/images/graemlins/cool.gif
Thanks to everyone... I'll try 'n remember to post results...
Dave...
   / New Cab Heater not working well... #18
Glad I'm not the only one who's heater seems not to be up to snuff. I attributed it to the large air gaps in the cab itself. Although, the air only seems lukewarm at times.
Don't forget to keep us updated.
   / New Cab Heater not working well... #19
I was having a problem with the heater in my 555E - similar type setup. Turns out there was air in the heater core. I bled the heater core by removing the return line where it "T's" into the main return line of the engine. It helped a lot.
   / New Cab Heater not working well... #20
On the majority of water baseboard radiators used in the HVAC industry they use some type of small vent automatic or manual to eliminate air in the radiator so that it heats to full capacity. You would think that the manufacturers of these cab heaters might take some initiative and add the very same to their products eliminating just this sort of headache. Bleeding air would then be an easy task.
set of 4 tractor trailer tires Roadforce (A56438)
set of 4 tractor...
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
