New Cat 299D XHP
   / New Cat 299D XHP #61
Ran 299d on these hot days and had no problems.Ran with a cimaf planer head,what a great combo.Found later that I was only running on 33gals instead of 40gals it did great on 33gals.Ringpower I told my cat rep to ck your mods.Robbie wish you could have made it to demo.
Sounds like it should cut well. I guarantee if I was there I would have made sure we were getting the right flow. Wish I could have been there too.
   / New Cat 299D XHP #62
Hi all, I just stumbled across this thread while trying to get some info on the CAT HM415 operation (3 hoses with 14 pin wiring). I need to know if the door can be opened independantly of the mulcher head spinning and i thought the best people to ask would be the guys at the levers. Best regards, Danny
   / New Cat 299D XHP #63
The door will work without the head spinning but it's sloooooooooooow!!!
   / New Cat 299D XHP #64
Thanks for the reply. Our's wont open unless the drum is spinning. Does the drum on yours go into reverse to clear blockages as ours wont for whatever reason. The pipes flex but a whole lot of nothing happens when the thumbwheel is placed into reverse.
   / New Cat 299D XHP #65
I will have to check and get back with ya, I always put it in reverse an hang it on a stump an back up to dislodge what ever has jammed in the rotor. Don't hold me to it but after I dislodged it I think I have seen it spinning in reverse while I was holding the thumb switch backwards. I'll check and make sure
   / New Cat 299D XHP #66
I have the FAE version of the 415. It will go into reverse a little to clear light blockage but if it's something wedged in there, I use a stump or big rock to roll the drum back.
I went with a hydraulic door instead of using electric over hydraulic so that I could open and close the door at will. Was told by the FAE dealer that unless my head was under load, the door would not operate..that is, if it was spinning up I could use the door but if the head wasn't encountering resistance, the door wouldn't work. That scared me off so I just ran hoses to my secondary auxiliary hydraulics.
   / New Cat 299D XHP #67
I checked mine it does not spin in reverse use the thumb switch, I guess when I saw mine spinning in reverse it was the force of pulling it backwards off of the stump to free the rotor. But my door does open and close without the rotor engaged
   / New Cat 299D XHP #68
You guys are life savers! I have had word from the chaps at CAT/FAE and they pretty much confirm what you say. The drum needs to be spinning for the door to work open/close and the drum will not reverse hydraulically. I think that is the way we will have to go yellowdog and put some extra lines and valve in for the door open/close. Thanks again guys.
   / New Cat 299D XHP #69
See if the electro hydraulic spool can be adjusted if it can open it up to increase flow it tighten it down to increase pressure I don't know how they plumbed it.
   / New Cat 299D XHP #70
nope, already tried....... its already maxed out..... there is a orface in the valve to prevent to much oil from being robbed from the drum pump
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
Land Pride RCR1260 (A53317)
Land Pride RCR1260...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
MORBARK 6400XT WOODHOG HORIZONTAL GRINDER (A60429)
MORBARK 6400XT...
