new disc harrow
/ new disc harrow #1
HD Labs
SC
1986 Massey Ferg 240
Looking for a disc harrow to use with Massey Ferguson 240.
Have looked at TSC and called a few places.
Leinbach 20 disc 20" is $990.
Taylor-Way 20 disc 20" is $1150
King Kutter 20" 20 disc is $1299 at tsc.
I;m leaning to the Taylor Way....
What is too heavy for my Massey?
Any other advice is welcomed. Is 6.5' about the right size for my tractor?
/ new disc harrow #2
800 lbs hanging that far back is going to make your front end light unless you have a FEL. 6 1/2 wide is about right. Ken Sweet
/ new disc harrow
Can you recommend what the best option would be for my size tractor? Weight and width.....that will cut ground up good and last a long time....
/ new disc harrow #4
You are on the right width at 6 1/2. Now get sealed bearings on the axles and adjustable tubular frame and weight you can handle and you are good to go. Ken Sweet
/ new disc harrow #5
I have a 1998 Massey Ferguson 231. It's 38 engine hp and 34 PTO hp. It weighs 4,100 lbs. I have a 6.5' United 3 pt lift disk harrow. 20- 18" notched disks turning on sealed bearings. Not sure how much it weighs, but it's really heavy and I think United is made by The Leinbach Line.
The tractor does EXCELLENT with this harrow. I'm Very pleased with the way it handles it...
Travis R
/ new disc harrow #6
Travis R
United manufactures their own line of disc harrows, and so does Leinbach. Both manufactures have different series of discs. I have carried and sold both lines.
/ new disc harrow #7
no dish harrow in the 6ft size 3pt hitch models will not cut ground here well if it has not been turned every year or every other year or cut with a larger transport disk first. Yes my little harrow will not work well, on untilled soil, and yes its an angle frame, my uncles will not work well either behind his 35 hp JD thats 4wd and has a fel and a box frame disk.
/ new disc harrow #8
I agree with it depends on the soil. I have a 6-1/2' Kingkutter 18" with 20 discs and I couldn't penitrate some old pastures that I had to tear up and wound up plowing first then discing. But, some real sandy type dry cheat grass was almost too soft gave my 35 hp 4 wheel drive a struggle. I need some mosture with my disc. bjr
/ new disc harrow
Any body ever use a WOODS disc harrow?
/ new disc harrow
Looked at Leinbach 300s with 16-18" disc and it looked like enough for what I need ... its 1200....does that sound right?
/ new disc harrow #11
We have the New 16-18 tubular disc made by Big Bee in Alabama for $675 + approx $165 shipping. Scallop blades in the front and plain in the back.5 1/2 ft cut Ken Sweet
