New GC2610 questions
   / New GC2610 questions #22
I have been using AMSoil Synthetic Diesel SAE 10W-30/SAE 30 for the motor, Synthetic Tractor Hydraulic/Transmission Oil SAE 5W-30 for the tranny and hydraulics, and Severe Gear 75W-90 for the front axles ( and my gears in attachments ) Have had no issues, squeaks or squeals,temp issues, etc... More money, yes.... but for a few extra bucks, i sleep better.... :thumbsup: These amazing machines are not cheap, so for me.... it is cheap insurance. My 2 cents.
   / New GC2610 questions #23
I used the NAPA fluid at the 50-hr change, with no discernable problems. At 250, I used TSC generic (equiv. to Permatran III) fluid. Seems OK.
One of these days, however, I'd like to replace with synthetic, if for no other reason than reducing warm-up time in the winter....
So far, it's just been a matter of convenience to use "normal" fluid.
   / New GC2610 questions #24
I would recommend using either Permatran, or Amsoil ATH synthetic. They are the only two that have been proven trouble free. Some have run other brands, and had no problems. And some reported issues.
I am using Amsoil synthetic in everything, except my front diff, I had some permatran leftover from my machine being delivered to me low on fluid. So I bought a gallon and used the remainder in my front end at my 50 hr. I will change to Amsoil gear at my 250hr. As ray66v said... it is well proven.
What about filters? Does napa/.wix make an OE replacement? Amsoi lhydraulic fluid seems to be around $45 a gallon. Napa premium is $14 a gallon. Does it really flow that much better when cold? My tractor will be parked in an unheated space. One more thing that I forgot to mention. Most people seem to say permatran III is the only way to go. I spoke to my dealer and they do not use Massey fluid. They use kubota fluid. They said if it meets the specs it is fine. Brand does not matter.
   / New GC2610 questions #26
I started a new thread on filters for you:
GC Series Filters, OEM And Aftermarket Part Numbers - TractorByNet.com
All universal hydraulic fluid meets the minimum spec. for you tractor, but it is not all the same. Each uses a different additive package.
I have found that different fluids run at different temperatures. Heat is a big factor in how long your transmission lasts. This is no place to try and save a few bucks.
If you can't get Permatran locally, my guess is the Kubota fluid is a good substitute.
The Amsoil, is expensive, normally twice as much, but I have not bought it lately, so I don't know this weeks price. People who sell this stuff will deal, so barter with them.
The specs for Permatran are very difficult to find published for comparisons like extremely cold weather performance. I did see them once, and the difference when you compare it to synthetic was not big. But, we do know synthetic lubricates better in cold weather, and when you see the long warm up times in the manual it is clear this is important.
I consider the synthetic oil the best option, especially when you consider it will last 2-3 times longer than mineral oil. I don't run my tractor in harsh dirty conditions, so I have no problem running it longer than the recommended interval with a filter change.
You can also add a silicone pad heater to the bottom of the trans. I use one like pictured below. It keeps the oil from getting real cold. Makes you feel a lot better about running the tractor when it's been sitting in below zero temps.
Engine oil heater/ oil pan heater 120v 150watt NEW | eBay
Thanks for all the info. I have no problem using the Amsoil if it truly will give longer intervals. I will be using my machine for lawncutting,snowblowing and chores around my 5 acres so I do not expect heavy use. What kind of extended intervals are we talking about? Are you changing the filter at the factory specified interval and leaving the hyd fluid in longer?
   / New GC2610 questions #28
Yep. :thumbsup:
I just logged 25 hrs over the last few days pulling stumps and grading. I noticed that when I pressed the diif lock it did not lock the other wheel. I purchased the factory service manual and it does not show anything about the diff lock. I do see a cable with an adjustment underneath. Any experience with this? I do not want to adjust the cable until I know for sure that is it. In addition I want to add that the service manual leaves a lot out. Another thing I noticed is that it doies not mention any adjustments for the cruise control. Tha manual is not as in depth as I would of hoped. I might of wasted $110.
   / New GC2610 questions #30
The diff lock requires the gears to allign perfectly for it to engage. This can take practice. It is common for new owners to have trouble getting it to work, (as well as the float controls on the FEL, and the Backhoe), once you figure it out, it will be fairly easy.
It is not usually simply a matter of pushing on the pedal. Unless the gears happen to be aligned, you will need to be moving very slowly, while applying just enough pressure to the pedal for the gears to mesh. It would be a lot easier to show you.
It will not always disengage right away, when you lift your foot off of the peddle either. You will not be able to get the machine to turn when this happens.
2008 CAT 305C (A53317)
2017 Makita HM1307CB 35lb Demolition Hammer (A55973)
2017 Makita...
2018 Ariens Ikon 52in Zero-Turn Commercial Mower (A56857)
2018 Ariens Ikon...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
