New Green 2305
   / New Green 2305 #11
Shawk said:
Hey Mayor... can you snap some close up shots on which wires your lights hook into? My 2520 had additional wires to run. But the only wire I found to run my 2305 lights off was the tail light wire. Thanks...
there is a set of work light wires under the left rear of the tractor. under the rops. you can follow the wiring harness to find them.:D
   / New Green 2305 #12
Outstanding!! Thank you Buddygunzz!! That's exactly what I was looking for!!!
   / New Green 2305 #13
Thanks Buddyg... found those. I was wondering if there were any others. Those are pretty skinny :) .... but I know they were'nt meant to run 3 lights like I have. I'll put a switch in to run no more than 2 accessory lights at a time. Appreciate the reply...
   / New Green 2305 #15
correct me if im wrong but those 2 wire are 14 gauge which should care 15 amp no problem and im running 3- 55 watt light and have 14.1 amps on the circuit. i do have a 15 amp fuse in the fuse holder.
wire chart amp.
AWG / Amperage (Up to 50' wire length)
AWG max. Amperage
0000 (4/0) 300 A
000 (3/0) 260 A
00 (2/0) 225 A
0 (1/0) 195 A
2 125 A
4 90 A
6 70 A
8 50 A
10 30 A
12 20 A
14 15 A
16 10 A
hope this helps
   / New Green 2305
Thanks for your help with the lighting questions. Have not had time to take any pictures.
   / New Green 2305
Hey guys,
Just finished my tool box add on and I think it came out ok. Took a few shots as I went along. Let me know what you think. The seat is all the way back and it only hit the tool box when getting on. The rubber strip keeps it from messing with the finish on the seat. This is a $35.00 project and it was very easy to do. Hope you enjoy the shots?
box9.jpg:
   / New Green 2305
What you can only post two pictures at a time????
2015 Chevrolet Tahoe, 192,897 Miles, Decommissioned Law Enforcement Vehicle (A56438)
2015 Chevrolet...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56436)
2006 Magnolia Dry...
CHECO HYDRAULIC GREASE INJECTION UNIT (A58216)
CHECO HYDRAULIC...
UNUSED IRMC HIGH END MASSAGE CHAIR (A58376)
UNUSED IRMC HIGH...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A56857)
2025 MS380R Mini...
2001 Ford Explorer SUV (A56859)
2001 Ford Explorer...
