New Holand 1720 Coments
   / New Holand 1720 Coments #11
My 2120 bought from the original owner (Ford tractor salesman's personal machine) is a 1993, no trace of New Holland name on it, Ford all over.
Jim
   / New Holand 1720 Coments #12
I own a 99 1720 with 550 hours...
I purchased it in 2006 with 245 hours...
Just got an FEL and pull a 6' RFM weekly in the summer...
Great tractor and very reliable...
I think that when NH purchased Ford they kept the Ford lettering for a few years and then transitioned with Ford-New Holland and then New Holland...
They are still the same tractor...
I posted the tractor was for sure a 1981.now I'm not sure what I got. The I.D tag was not on the tractor. I Recived a operator's manuel with the tractor and inside the cover was a I.D tag from New Holand *UL423XX Model AL 413A Engine #N843-598XX Unit 9E258 The tractor has the 4-speeds on the left side of the seat and 3-speeds with reverse near the steering column. It has 3200 hrs on it. Sorry for the confusion. I guess I was told it was a 1981 fron someone who didn't know.
   / New Holand 1720 Coments #14
Maybe you got a 1981 Ford 1700 with the wrong owners manual for a 1720. Post a picture.:confused2:
   / New Holand 1720 Coments #15
leftybob, it sounds like you have a 1720, but its not a 81. The 1700 would have 2 shifters under the seat. Some 1710's had a similiar setup as the 1700, and some like mine have 1 under the seat and a 3/R steering column setup (like you said) but none had a shifter to the left. I got a few hours on my uncle's 1920. That has a setup like you described. And since the 1720 is only one size smaller, seems logical for it to have the same setup.
   / New Holand 1720 Coments #16
I just noticed you said the shifter was near the steering column...the 1710 shifter is built into the steering colomun. Also, if the tractor has a oil bath air filter, it is probably a 1700. There might be other little details to look for but Im unaware of any.
   / New Holand 1720 Coments #17
I have a 1992 Ford 1720 with about 2030 hours. It has a sims full metal cab with upper and lower doors with glass. I primarily use it to haul cord wood, Split and chip wood and remove snow. I also use it for improving my lot.
I just bought a used Woods BH with subframe that is being removed from a
'94 1720 NH. The previous owner is going to give me the parts for attachment and Hydo connection which I will put on my 1720. Then I need to get my 1720 to his place an hour away to attach the BH and bring it home. Seems like a crazy process but the only one we can come up with...
My pto clutch doesn't work but the drive clutch is very strong. I am going to have a mechanic check the adjustment and peek to see if the pto side is rusted.
   / New Holand 1720 Coments #18
I have a 92 1720 and the shifter's are on the left, only control below the seat is on the right one for the axle lock and the handle for the 4 wheel drive. there is a tag on the right side of the eng. below the oil dip stick where you control the hyd system. Hope this helps if you need more info let me know.
IRanch High-End Electric Tricycle (A57149)
IRanch High-End...
2018 CATERPILLAR 336F L (A58216)
2018 CATERPILLAR...
2018 Ford F-150 Pickup Truck (A56858)
2018 Ford F-150...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
2018 John Deere 6195R (A57148)
2018 John Deere...
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
