New Holland 848 Baler Guidance
   / New Holland 848 Baler Guidance #11
if the chains are that stretched , removing links will shorten the chains , BUT the worn links will now wear the teeth on the sprockets pretty quickly
for power , run a # 12 or #10 gauge wire with a 20 amp fuse ... but do the smart thing , run it inside an old garden hose for added protection ... use FINE multi strand wire , not solid wire ... put the fuse as close to the battery as possible ( so if the wire grounds anywhere , the fuse pops instead of cooking the length of wire )
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1304 (A58374)
1304 (A58374)
INBOARD DRIVE (A58374)
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
SPRAY TRAILER (A58214)
