melmark
Bronze Member
By the way white smoke on start and rough idle usually means there's air in the fuel injection system. Often this happens after a fuel filter change and the system is not bled completely. That was my first thought, either not bled properly or an air leak from the filter not installed properly.
If it was not bled properly after the fuel filter change would it push the air out after some operation or would the problem persist? I could bleed the system as described in the manual. It has been a while since the filter was changed and the problem has remained consistent since then. If there was air in the system does it make sense that it would "clear up" and run fine after 3 or 4 seconds? Not debating...just asking, trying to learn
Thank-you for the response guys
Mark
