New holland Tachometer issue
   / New holland Tachometer issue #11
Before getting all carried away with wires, circuits, grounds, and other complications try putting a voltmeter on the AC output of the alternator (the post that powers the tach) and see what it reads. Most other model New Holland tractors with alternator driven tachometers need to see around 8 volts AC or they don't work right. See what you have. The problem may well be the alternator, not wiring related at all.
   / New holland Tachometer issue #12
I would have thought that this tractor has a cable driven tach/hour meter?
   / New holland Tachometer issue #13
If you don't find anything by checking the connections, these documents might give you further insight.
  • Tachometer - 1.pdf
  • Tachometer - 2.pdf
I think I found the problem, Mice
Had a good time behind the dash.
   / New holland Tachometer issue #15
Count yourself lucky it only impacted the tach.
   / New holland Tachometer issue #16
That does look like a/the problem šŸ˜
2004 FORD F-350 XL DUALLY CREW CAB FLATBED TRUCK (A59823)
2004 FORD F-350 XL...
Toro Utility Cart (A59228)
Toro Utility Cart...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2018 KENWORTH T680...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A60460)
2019 Caterpillar...
2007 Western Star 4900 Semi (A59814)
2007 Western Star...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
