New Holland TC33D
   / New Holland TC33D #21
I love it when a plan comes together! Happy tractoring, I'm off to the daugther's soccer game.
   / New Holland TC33D
OK guys, Next issue. Ho do I lift an implement, attached to the rear PTO, off of the ground. I have moved the levers in every position, and nothing. The back hoe is still attached, but I trying to make sure that the lift works, before I go through the trouble of taking off the back hoe. I have had nothing but trouble with this thing since I bought it. I do not see a line that needs hooked to anything to run the lift arms. Please help.
   / New Holland TC33D #23
You have to remove the backhoe to operate the 3PH. When you remove the backhoe, there will be a hose that you attach to the open fitting.
   / New Holland TC33D
I removed the hose that you would disconnect if removing the backhoe. There is a short hose which connects under the seat, and a longer hose that runs to the middle of the tractor under the seat area. I disconnected the longer hose and attached it to an open fitting, which is located on a block of sorts, towards the loader on the right hand side of the tractor. I then moved the PTO levers to every possible configuration. Nothing. I have had nothing but trouble with this tractor.
   / New Holland TC33D
Sorry guys, bit of an over reaction. Other issues. Tractor has been pretty good. Figured out the lift arm issue. Thanks much for your help.
1994 Blue Bird Command Center Bus (A55973)
1994 Blue Bird...
2018 MACK CHU613 DAYCAB (A58214)
2018 MACK CHU613...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58018)
2019 FREIGHTLINER...
HOG COOKER MTD ON S/A TRAILER (A58374)
HOG COOKER MTD ON...
LOT: Assorted Hammers (A59076)
LOT: Assorted...
Mini Skid-Steer Steel Mounting Plate (New/Unused) (A59225)
Mini Skid-Steer...
