New Holland TC45 backhoe inop
   / New Holland TC45 backhoe inop #1
AlanT
Loaded the tractor no prob went to unload backhoe inop front loader ok changed positions on diverter valve no change no pressure going to rear hydro lines feel no pressure going threw valve when changing positions what next is the diverter valve no good
   / New Holland TC45 backhoe inop #2
If it was working fine then suddenly went belly up after transporting it, I would look to see if there is a quick connect hydrualic line that is loose. Disconnect everyone and firmly reconnect. Then try it again.
Did that twice no pressure to the rear hoses front bucket works ok
   / New Holland TC45 backhoe inop #4
Do you have remote hydraulics in addition to the backhoe? If you do, check that the lever is not sticking, causing it to not return to center. Your FEL is before the remotes in the open center system, but the 3PH and backhoe are after the remotes I believe.
Also, sometimes the loader valve itself has a power beyond plug that loosens.
Here is a thread that talks about it. I think it would have the same effect on your backhoe. I've attached a diagram that shows where to check for this.
EDIT: Just a suggestion. A specific question like this will normally get quicker and better responses if you post it in the New Holland/Ford Owning/Operating forum. I just happened to look and see your post as I was scrolling down the page. This forum is for general repairs that would apply to all tractors. It's okay that you put your question here, but in the future, you might be happier with the responses by placing specific questions in the NH forum.:)
   / New Holland TC45 backhoe inop #5
Chances are a plug has come out inside your loader control valve. Underneath one of the outlet fittings (either the PB fitting or the 'OUT' fitting) is an Allen headed plug that keeps the PB flow from comingling with the 'out" or 'Tank' flow. This plug has probably backed out and is allowing PB oilflow to instead go directly back to the reservior.
   / New Holland TC45 backhoe inop #6
RickB and others, the OP told me in a PM that his Allen head plug was the problem and he has his tractor repaired and operating normally.:thumbsup:
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A55788)
2017 Ford F-350...
New Holland TS 75 Front Loader Utility Tractor (A53421)
New Holland TS 75...
(INOP) 2013 INTERNATIONAL WORKSTAR 7500 6X4 DUMP T (A51406)
(INOP) 2013...
Cat 963B Track Loader (RIDE AND DRIVE) (NICE) (A50775)
Cat 963B Track...
2006 GMC W5500 Dovetail Flatbed Truck (A55788)
2006 GMC W5500...
Giyi 72" Box Broom Sweeper (A53316)
Giyi 72" Box Broom...
