New Home Building
   / New Home Building #31
I have read this thread with some interest because I am in the process of building a new house - and I am doing all of the work myself. Dug the basement, formed and poured footers, built forms, poured the basement walls, the basement floor slab, etc. The only thing that I have contracted so far (and all I have planned to contract) is the installation of the septic system. I spoke with the inspector and she said I could do it myself, but it seemed very troublesome as compared to the quote that I got from my (licensed) installer. I have a neighbor who has been trying to install his own septic system for the past fourteen months, and he still can't make the inspector happy.
Yes, building a house doing the work yourself is very time consuming, but I'm not sure how that time could be better spent. You know all of the details of what you are doing, but you also have to be responsible for getting every last bit of material purchased and on site. I find spending time working on the house very rewarding, and I don't have to worry about someone taking a shortcut while I'm not around.
On a side note, I guess I don't understand what is wrong with using concrete form lumber in the building of a house. I plan on disassembling my forms (made from 3/4 plywood and 2x4s) and using them as framing material. The lumber has only been out in the weather for a month or two, rained on less than 10 times, and still seems very structurally sound. I can understand if the lumber is truly rotten, I wouldn't use it, but if it is strong enough to hold concrete walls in place while they are poured, it's strong enough for me.
Of course, the owner-builder will inevitably take longer to build the house than the owner-contractor (in most cases), but five years down the road, it won't matter that much.
Finally, there is a quote that I can't remember exactly or who said it, but it goes something like "The miracle that is a brick is lost upon the man who has never placed one".
Good luck and take care.
   / New Home Building
rtim
Not sure where you are but in NY you need to leave the tank, d-box and one leach line open for inspection by the county before you can bury it. And in my opinion I'd set up the septic dig so you can be there to take pictures and check the work in progress. I did and saw them using lazer levels and the like to make sure pitch was correct ect... and when done they put water in the d-box and adjust water level to all the lines so one isn't overloaded more than another. It's all important stuff. I got quotes to use plastic and concrete but IMO it's concrete I'd go with. Plastic over time becomes brittle and will crack. Concrete has a better shelf life
   / New Home Building #33
Here the entire system has to be left open for inspection - I was there the afternoon that the guys were putting the system in. I didn't take any pictures but I set up an instrument and shot stadia to locate all of the tank/box/lateral line end points and put them on my plot plan. The guys doing the installation are familiar with all of the requirements of the inspectors. By being licensed, it just means that the inspector can come look at the entire system prior to it being covered (they have to leave inspection pipes in place for her to shoot the level of the lateral lines, d-box, etc). If I were doing the installation, she (the inspector) would have to come out for every step of the process. Luckily, the work is already done and the system is approved - it took them less than two days. The d-box and septic tank are both concrete.
2019 TAKEUCHI TL8 SKID STEER (A51242)
2019 TAKEUCHI TL8...
2022 McConnel TRAXX RC28 Remote Controlled Slope Mower (A51691)
2022 McConnel...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
