Just getting started on house plans but my recommendations are:
1 story, NO basement!
Don't let a builder tell you that a 4 ft frost wall is required on your slab. It is bs, slabs for cold climates are easy to design and build, just requires proper drainage under them.
Token tractor comment, buy a tractor! You'll use it more than you think! I know we use the neighbours more than they probably anticipated!
Put in a bigger septic tank than the minimum and take lots of pictures and measurments for digging it up to get it pumped!
People spoke about circulating hot water etc, you can find instant on hot water heaters for good prices that will save $$ in the long run. Circulating hot water and dual heaters is really inefficient.
Think about wooden siding, rough cut boards are pretty cheap and last a really long time. You don't need to paint them, you don't need to do anything with them actually. If your overhangs keep water off and they don't get splashed at the bottom they will just darken. If they get wet they will go barn board grey. If you stain them you will have to restain every 10 years or so on the south side. For god's sake don't paint them! It a viscous cycle of scaping and painting!
Think about using non opening windows whenever possible, they are cheaper, more secure, more efficent and lots of other things. Install intake vents at floor level and larger exhaust as high as possible, natural circulation will do amazing things!
Big overhangs on south wall, shade windows from high sun in summer, lets in low sun in winter.
Pressure flush toilets! The old american standard toilet has reached the end of it's life I say.
Entry porch / vestible - the 2 sets of doors really cuts down on air exchange when bringing groceries etc inside saves dropping/raising the temp of the house right when you get home.
Indirect flourescent lighting - office buildings are finally learning that a direct light doesn't do anyone any good, put it behind a reflector! Use 2+ lights near edges of rooms instead of one in the middle, less blocking your light and makes for better reading etc.
A really good resource is titled "Your Engineered House" it was written in the 60's but most of the material discused is starting to show up in current houses!
Ken
