New JD4520 cab is destroyed
   / New JD4520 cab is destroyed
How many people get to have the joy of their new tractor being delivered twice :D:D:D This is the view from the side that had the barn resting on it.
I also had a bigger weight bar put on it and added 4 70# weights. Added my existing 6 40# weights from the JD 318. Need two more to fill it up, will get those this week. Someone commented when I 1st got the 4520 if I was going to add some weight for the MX6. Since everything is being converted over to iMatch (quick hitch), the front weight requirement goes up a bit.
Also, an attachment followed the tractor home! I couldn't send it away, that would be cruel ;).
Also have my TnT on there now, will revive a thread I had on that and continue that saga.
But this event is not over, I still have to see what State Farm decides to cover and do.
Pete
   / New JD4520 cab is destroyed #83
Pete,
Very good to see the tractor whole again.:thumbsup:
Nice looking landplane too, looking forward to your comments after using it.
   / New JD4520 cab is destroyed #84
Looking at the picture, I would have to agree that the landplane really wanted to come home as it seams to have led the way.
Pete
Looks like the dealer took the tractor for a test drive though...It's got mud on the tires. Better send it back and tell them it doesn't match the attachment for cleanliness. LOL
The tires and the attachemnts will be much better matched real soon... ;)
Pete
   / New JD4520 cab is destroyed #86
Pete
Good you have your unit back. i hope State Farm covers it all.
Well, the last chapter in this epic saga have now been written. I got a check from State Farm Insurance. It's one of the odder settlements I've got on insurance, and on balance I'm happy with it and with State Farm.
They covered 100% of the tractor repairs. The building part threw them for a bit of a loop. I had about $200 in direct cost, and about 17 hours of time doing the extraction. The locals are deconstructing the barn for wood and tin, so I suspect there will be near zero cost there and maybe a half day of tractor time to scrape the site clean. This saved $4600 over a quote to demolish and cart off the building. And that's money saved for all policy holders.
The building was a 32 x 84 core, with 16' extensions on each side. One of the side extensions was not very accessible (it was built to feed cows). I was in the process of building a 30 x 40 Morton building when the collapse occurred (what a difference a month would have made!). So I told State Farm that if I could put up a 30 x 40 building, between that and what I built I'd be back at the core amount of area I was using. It would have cost $18.3K to build that. The one I was building was $23.5K but it had a concrete floor. Finally, to further confuse things the collapsed building was an open sided pole barn, the Morton is a fully enclosed pole barn.
So it's a challenge to compare old open pole barn to newer buildings, to figure out how those cost trade off, and to come up with a value for the building. As for my extrication, I think insurance companies like bills from licensed contractors and have a hard time with "stuff the home owner does". And I can't blame them in this regard, after all how do you evaluate the homeowner's efficiency. I did not specify an hourly rate for my work and said anything they wanted to pay was fine. From my perspective, getting the tractor out with no more damage (thus insuring it could be fixed vs. having to be totaled) was worth the time. All those aspects and trade offs are covered earlier in this post.
So I told State Farm I'd be happy with covering my extraction costs and a 30 x 40 dirt floor building because when used in conjunction with what I was building, I'd have the same functionality. Talking with the adjuster on the phone, he said that my policy was for a replacement and that State Farm felt that they should pay for the building that fell, even though that was more than I'd said I'd be happy with. When the check showed up, there were a number of pages where calculations were done (a computer program) to determine the cost of the building. This included cost of roofing metal, trusses, poles, the contractors mark up, and the like. There was also a depreciation in there, which I don't entirely understand because the policy is (in theory) for "full replacement". But it was only 10%. There was no amount for my extraction. It stated that if I incurred demolition costs, that I could submit that for payment.
The final value for the collapsed building (4000 sq feet, no sides, and with poles in it) was a bit more than two of the 30 x 40 Morton dirt floor buildings (no concrete, total square footage 2400 but with sides and doors). As such, I will have about the same usable square footage as I had before. It's really a bit less room, but, these will be buildings with side so in an apple vs. orange comparison it's just fine, and the values work out OK. I would have no loss in functionality and have the improvement of sides and doors.
I think that part of what's going on here is a claim that had too many "out of the box" pieces to it as far as the nature of the structures, homeowner involvement, local "Free" demolition, and the like. I think State Farm did an OK job of fitting their settlement tools around the problem. If you can get through calamity by being so close to breaking even that you can't tell, then you've done great. You're going to have time in the process and expecting to be paid for that is unrealistic. What I did not get for my extraction is covered by the building value less my deductable. It's like everything else in life- deal with it, fix it, learn, and get back on it and get to work (the tractor that is).
I will be reviewing my insurance policies to make sure everything is covered. Some people posting to this thread had bad surprises about limits of coverage in their policy. Now that I will have all my tractors under one (new) roof, I want to be sure I'm OK. The building at the collapse site will hold implements, my trailer, and store other items.
This event also shows the value of having cash for a rainy day. I was able to just tell the Deere dealer to fix the tractor, then pay them. State Farm was not able to get an estimate from the Deere dealer for whatever reason. A paid bill and working tractor took out all the variables for the insurance company. So having the cash and being able to wait for a settlement helped the process. Time also let the demolition process play out. If I incur cost to finish the demolition (if there is too much big stuff left after the scavenging) I can go back to State Farm and give them a bill from a contractor to haul off the rest of the debris. At any rate, having time reduced the number of unknowns and let the settlement process happen more smoothly. And everything I paid for are all things that would have to happen no matter what, so why not get things rolling as fast as possible.
So I'm happy with it all. I will have all the functional square footage I was using before the event when the 2nd building gets built. I'm happy to trade off a little less room for enclosed buildings with open interiors and doors. I'm happy that State Farm is showing some flexibility in dealing with this claim.
I hope people learned things from this thread, and hope my long windedness wasn't too annoying for y'all.
I was out working on my dam hand cutting and clearing brush yesterday. It was great to then take my tractor and do the final trim of that area with the sickle bar mower.
:tractor: = :dance1:
Pete
   / New JD4520 cab is destroyed #89
eepete thanks for the wrap up. it also was very informative.
   / New JD4520 cab is destroyed #90
Pete,
Good deal:thumbsup: Alls well that ends well.
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
UNUSED FUTURE QST HYD MINI SWEEPER MINI SKID STER (A58376)
UNUSED FUTURE QST...
CAT 930M (A58216)
CAT 930M (A58216)
2020 Kenworth T370 T/A 4,500 Gallon Water Truck (A56858)
2020 Kenworth T370...
PARTS ONLY - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - 2023...
2021 TAKEUCHI TL12V-2 SKID STEER (A52709)
2021 TAKEUCHI...
