New L2550 owner - how to start the tractor (?)
   / New L2550 owner - how to start the tractor (?) #1
L2550
PA USA
Kubota L2550
I bought an old L2550 and it's just arrived in my yard.
It's cold and rainy and I'm trying to start it (no manual
or instructions with it). I turn the key left and hold it for,
maybe 45 seconds. I then try cranking the engine and
just NOTHING happens at all. I depressed the clutch,
the brake, the clutch AND brake, and I can't get a sound
out of it. Is there some magic setting of switches or
levers that I don't know about? I'd like to move it out
of the weather before the seats get (even) worse than
they are now. It has a front bucket loader and a rear
backhoe attached to it. I'm going crazy!
Thanks in advance for any insights. /forums/images/graemlins/confused.gif
   / New L2550 owner - how to start the tractor (?) #2
Are you putting the hi/low range lever in nuetral ?
Hi-Lo Range Lever? I don't know.
Is that the vertical lever to the left that shows
a turtle and a rabbit and an 'N' in between?
(sorry ... there's just no indication of what
anything is on this machine ... just arrows for
fwd and back and then those rabbits and
turtles). /forums/images/graemlins/blush.gif
   / New L2550 owner - how to start the tractor (?) #4
Not sure if the 2550 is the same. It prolly is. I have a L2500. To start it you must have the High/Low range in Neutral, the PTO disinganged, shove the fuel valve forward (this opens it) I also push in the clutch. When you turn the key left you are heating the glow plugs. Yes the lever on the left should be your high/low range. Or maybe you can call a dealer I am sure they can help.
Thanks so much for the help. I was about to go out and
check if it'll start but it's cold and dark and snowing now.
I'll check it out in the morning; maybe if I can get it going
I'll move some of the snow accumulation around for a
test of my skill (or lack thereof).
I'll let you know how it goes! /forums/images/graemlins/laugh.gif
   / New L2550 owner - how to start the tractor (?) #6
sounds like u have a safety interlock, either tranny( netural) or pto engaged. if it was just fuel, it shoul crank , but u said NO SOUND. so it is not even trying to start.
   / New L2550 owner - how to start the tractor (?) #7
I'm not sure if anybody asked this, so I will. Is the battery charged and are the cable connections clean?
Andy
SUCCESS! finally. (it's embarrassing). Turns out that I
didn't have the clutch FULLY depressed. The seat is all the
way back and won't move forward. I didn't realize at the
time that my left leg is just too short to get the clutch pedal
all the way down. I followed all the suggestions and then
sat on the very edge of the seat and STOMPED the pedal
down and the tractor started right up.
I practiced moving a dirt pile from one place to another and
made a right mess so my next problem is learning how to
use the tractor properly -- it looks a lot easier than it is!
Thanks, everybody, for your help in solving the problem. /forums/images/graemlins/smile.gif
   / New L2550 owner - how to start the tractor (?) #9
Hey, you owe us some pics for the advice!!! /forums/images/graemlins/grin.gif
   / New L2550 owner - how to start the tractor (?) #10
Hey guy, I got a L2550 recently also. Have the loader no backhoe.
nterested in knowing what type/model of backhoe you have on yours. How well does it work.
Thanks don't check , replies to often, but I'm eager to hear from you.
My L2550 runs fine, but will need a new clutch someday.
2008 Chevrolet Uplander LS Van (A55853)
2008 Chevrolet...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
GRINDER (A55745)
GRINDER (A55745)
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
New/Unused 78in Quick Attach Skid Steer Grapples (A54865)
New/Unused 78in...
2005 INTERNATIONAL4300 WRECKER (A56129)
2005...
