bdhsfz6
Elite Member
- Joined
- Apr 11, 2015
- Messages
- 3,188
- Location
- Northeastern Pennsylvania
- Tractor
- Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
Keep us posted on what you find out.
I have 3 rear remotes and all of them leak down making my HYD side link pretty useless without having to constantly adjust.
Hopefully your will be better.
I have 3 remotes on my MX5800 which also leak down. This occurs with the Kubota T&T cylinders as well as the ones from Fit Rite so it is definitely the valves. It isn't an issue with the top link but as you say, the side link is a real pain. As a result, I usually remove the side link cylinder unless I'm using an implement like a stone rake which requires it. It's easy to do on the MX since the side cylinder is attached to the lift arms with lynch pins and no tools are required. Unfortunately, this isn't true with L series tractors which use a threaded pin requiring the use of a wrench to remove.
