Flail Mower New Land Pride FM25 series flail mowers
   / New Land Pride FM25 series flail mowers #51
I still have the FM 25-84 referenced in my earlier posts. It has been trouble free mechanically, although I haven't put a ton of hours on it. I reviewed my previous comments and haven't changed my mind about the conclusions. My tractor is a 55 hp. Case IH 55 CVT which is adequate but not overly so. I can't comment on the JD you plan to use as I'm not familiar with the specs.
   / New Land Pride FM25 series flail mowers #52
This thread has been dormant for a while, and since I am about to pull the trigger on a Land Pride FM25-84 I am hoping someone may have had some experience with that unit. I will be powering with JD 4066R, and hoping to be abe to use E-PTO if I don't let the fields go too long between cuttings. Mostly pastures with not much other than an occasional down limb. Located in west middle AL., so terrain is not terrible.
Thoughts and or suggestions?
Jeff
r
Hello Jeff,
Spend your hard earned money on the John Deere 290 flail mower or the
John Deere 390 if your mule can lift it.
The John Deere 290 or John Deere 390 flail mower will provide you with a
trouble free drive system with a three row finish cut side slicer knives that
will be easy to sharpen with a Micromark wet well grinder.
Before Land Pride was swallowed whole by kubota they entered the flail mower
market and imported MASCHIO flail mowers in Land Pride paint.
I do not think the kubota made flail mowers are of the same quality of build as
the MASCHIO Flail Shredders that is why I think you should invest in a John
Deere 290 or 390 flail mower.
   / New Land Pride FM25 series flail mowers #53
Appreciate your feedback, the JD is 66HP with 57HP PTO rating. So I should be ok, but like you adequate power just not great.
RHINO X1406 LOT NUMBER 64 (A53084)
RHINO X1406 LOT...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
LOAD OUT AND SHIPPING (A51573)
LOAD OUT AND...
2016 John Deere 318G Skid Steer Loader (A51573)
2016 John Deere...
