New member, New Tractor MX 5100
   / New member, New Tractor MX 5100 #11
Yes the same as the commercial spray on, but I used the Plasticote brand, they sell it at Tractor supply, both it and the Herculiner brand,. I bought a gallon, but have a lot left over, I used a small roller after scuffing it with 600 grit sandpaper, and using some "goof off" to clean up the dust after the scuffing process. I took all the parts off and did the coating job in the shop, but if you are good at masking, it might go a lot faster. Follow the link and you can read about my saga.
James K0UA
   / New member, New Tractor MX 5100 #12
you just cant beat an MX5100 hst in my book.
   / New member, New Tractor MX 5100 #13
I didn't notice the link before, thanks it looks good. How long have you had the coating on the platform? I had the rubber mat on my 2900 and it was sort of a pain over time. The little rubber stops separated and broke off and it slid around some.
Thanks again!
   / New member, New Tractor MX 5100 #14
been a little over a year, and about 100 hours.. holding up well so far, and of course it would be easy to fix any scuff's.
James K0UA
   / New member, New Tractor MX 5100 #15
Yes, I really like the performance and functionality of the machine. It is taking awhile to get used to the HST, my 2900 had the synchronized shuttle shift and I still want to use the clutch, but I am getting there. My son has the 5040 and it is much quieter than my 5100, but it does not have the turbocharger, so I guess that adds to the noise as well as the hydrodrive. The power and stability are really great and I have been using the bucket a lot. I did order a toothbar for it so I can hopefully get more level cuts. I didn't have a toothbar on the 2900 (4WD) and I had a bucket on an old Ford 4000 2WD that I sold years ago. It was a good old tractor, but you really need 4WD for effective loader use.
   / New member, New Tractor MX 5100 #16
James K0UA
Thanks, I plan to go to TSC to get a 3pt ball hitch attachment today. I will check out the coatings while I am there.
   / New member, New Tractor MX 5100 #17
I have a MX5100 with the FEL also, not the HST. I also have a landpride 1872 brush cutter. I do not have the rear remotes, wondering if I could get the larger cutter like you have and use the connection for the FEL. Is that
possible?
Thanks for any help....
possible?
I am certainly not the expert but I don't know why that wouldn't work. All it does is raise the mower for transport. It sits on spacers put on cylinder when in mowing position. I wouldn't begin to know the right place to connect it though but I'm sure somebody here can enlighten us.
   / New member, New Tractor MX 5100 #19
yes you can use the loader remotes to raise an lower the mower.i was talking to my salesmen yesterday about a notill drill an he said if i rented the pull type notill drill an he said i could plugg into the loader remotes no prob.
   / New member, New Tractor MX 5100 #20
I'd like to know how she cuts with that 10'er. I have a 6' hog and she cuts fine with that if its not too thick but i don't know if mine would handle the 10' in tall thick grass.
do you have any action shots?
Brian
23169 (A50324)
23169 (A50324)
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
1994 Mack CH613...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
2001 Sterling Acterra Dump Truck (A50514)
2001 Sterling...
Wolverine Quick Attach 80' Bucket (A50514)
Wolverine Quick...
