New member with a gasket question
   / New member with a gasket question #1
coachrusty
30 min West of Indianapolis
Yanmar YM1700
Hello all,
My name is Rusty Hughes and I am a new member to your wonderful, informative site. I've been lurking since mid-February and I have read so much my brain is all confused most of the time. But with time and patience and hard work I know I've learned a lot already. I have attached a pic of my tractor which I bought for $2500 and that included a NH dirt scoop. It's probably a VN rebuild but I don't care about that right now. It fit my budget and I've got the resources to fix anything that needs it.
I have already managed to crack the front axle driving into a hole but that was repaired by a friend of mine. The tractor came with rice tires but a local tractor shop had a set of 9.5-24 turfs that he sold me for $75 apiece. The turfs came off of a brand new tractor that the owner brought back and demanded bar tires. I'm estatic over the turfs.
Back in May after I had tilled 3 acres of land I noticed that both rear axles seals started leaking hydraulic fluid. The leaks started at the same time and they leaked the same amount. After some investigation I believe the fluid in my tractor is not the correct fluid. So today I drained it and am planning to add a JD 303 equivalent (Shell Rotella) tomorrow. However, I am having a problem with the gasket on the strainer. The gasket was like a cardboard material and it split in two when I removed the strainer. Do I need to replace the gasket and what type of material should this gasket be? I'll order one from Hoye in the future when I change the fluid (I got an owner's manual from them , THANK YOU!) but I do need to get something tomorrow for this gasket.
Thanks in advance for taking the time to help a newbie.
Rusty Hughes
   / New member with a gasket question #2
Just clean both surfaces and apply Permatex Hi Temp RTV Silicone Gasket Maker per instructions, from any autoparts store.
   / New member with a gasket question #3
That's a great price on those tires!!!!!
Thank you Normde2001. I will do just that.
Eddie, I could not throw my money at him fast enough when he quoted that price. He definitely wanted to get rid of them and I definitely wanted them.
   / New member with a gasket question #5
You could also buy some gasket material from the same auto parts store and just make one, use the old one for a template and just cut it out with a pair of scissors.............
Oh, and welcome to TBN, nice tractor!
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
2025 SDLanch SDLL30 Mini Stand-On Track Loader Skid Steer (A56860)
2025 SDLanch...
Sedan (A59231)
Sedan (A59231)
Hydraulic rail grinder (A56436)
Hydraulic rail...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
JCB 2145 (A47477)
JCB 2145 (A47477)
