JC-jetro
Elite Member
Hey....had to go out of town on business.....
I'm back and going to take the tractor by the shop tomorrow
They seem to think that the clutch is stuck.
Apparently this happens often enough that ford put a small lever on the back side of the clutch pedal, so when stored for lenghts of time the clutch can be locked in the disengaged position.
The service manual costs $200 plus dollars....It is going to be cheaper to let them diagnose the problem.....go figure
the PTO will engage with no load on it......it will also engage under load as long as the end shaft is spinning at a reasonable speed.
A block of wood (small chunk of 2x4) is what I use.
Your observation reveal a different thing to me. If PTO engages with no load on and it leads me to believe that mechanical linking (sliding coupler) between PTO input shaft and PTO final shaft is okay and it stays locked in.
Your observation that PTO under load only spin at certain rpm ( or torque) leads me to believe that your pto clutch is actually slipping and not able to maintain the torque required by rotating implement. That is caused by either worn out pto clutch disk or adjustment. if adjustment is bad, it is likely yo have some issue changing gear as well. There is only one clutch release fork. Do you have grinding when you change gear?
Hopefully adjustment is all you need although your observation does not fully support it.
JC,
