new owner needs PTO help
   / new owner needs PTO help #21
The 1720 might not have a two stage clutch. I know on my 1900 that it was a option. And mine does grind when trying to engage the pto lever if I don't let everything spin down to a stop. There's no syncromesh on these trannys.
Steve
   / new owner needs PTO help #22
the lil pedal below the brake is a spring-return throttle pedal to use if you need to give it a little goose if the engine bogs. Let off of it and the throttle goes back to it's original setting.
the diff lock is located behind your left heel.
Yes, you prob. need to adjust the clutch pedal linkage. it is a two stage clutch. push in part way and it disengages the drive, push it all the way to the floor to disengage drive and pto. You just unscrew the locking nut and screw the linkage a few turns, then tighten down the lock nut. (I have no clue which way to go.)
You start with the clutch pushed in all the way, then slowly release clutch till pto kicks in. let it get up to speed (just takes a second), then slowly let clutch out all the way. Practice first in a low range...it takes practice to do it in 12th gear.
Yep, you must be stopped to shift gears or ranges!!!
You can't always shift gears, go from 2 to 4wd and turn pto on/off all at same time. Push clutch in, move pto lever or 2/4wd lever, let out half way, depress fully again then change gears.
(owned 1510 for 25 years...great little tractors)
   / new owner needs PTO help #23
Well I just left my farm...I got the PTO to engage....It wasn't easy.....quite a bit of grinding, but it did engage.....Didn't sound normal.
Looking at the pedal linkage....it looks like a simple adjustment to increase the throw of the pedal....I just ran out of light.
I hope the manuals i pick up tomorrow will explain this procedure.
I sure hope this is all i have to do......spending 1K on a tractor that I only paid 4K for doesnt sound right....Oh well.....JC the tractor does have just over 2000 hrs on it...
And buy the way.....Tractor supply doesnt have manuals for any Ford tractor built after 1940....in case you needed to know.....Sent my wife.....boy that was an interesting phone call
I bought my 1953 8N manual there 10 years ago
   / new owner needs PTO help #25
Are you sure about that. Mine is behind my right heel
Bill
Ditto Bill. my diffy lock is on my right heel as well.
Sean, TSC does do special order on the ones they don't have on hand. They happened to have a copy of IT FO-44 on the shelf when i bought it 5 years ago. I sure do all I can to avoid a tractor split. if you ask a shop to change the clutch for you, they probably do it;) but you want to make sure you need it first. On several thread guys gave you instruction on how you test it out, read the manual, do all the test and report back. Hopefully, adjustment is all you need.
JC,
JC,
Will do.....
I live in metro Georgia....our Tractor Supply Stores here have minimal tractor gear.....they cater to the horse crowd.....clothes, horse feed and the like.....I'm headn to a dealer...
I'll report back
Thanks again............Sean
   / new owner needs PTO help #27
I may be L/R challenged! Anyhow, it is at one of your heels.
   / new owner needs PTO help #28
1720s had two different shift options, 12x12 Shuttle or 12x4 standard, but both had the 2-stage PTO clutch. To shift the PTO, clutch pedal MUST be pushed all the way to the floor-board. If grinding still is ocurring, then adjustment is probably needed. I could not however find the procedure listed in the 1720 O&M manual so you'll probably need to get a service manual or see if your dealer will let you copy the few pages from one they likely have.
On a related note, the tractor SHOULD NOT start with the PTO engaged. Even on the 20+ year old 1720s, that was a safety interlock.
   / new owner needs PTO help #29
1
I totally agree if there is a load attached to the final pto shaft(Ie. brush hog...). The purpose for my suggestion was to see if pto turns and trying to avoid grinding without it actually hooked to any implement . I don't have factory PTO safety switch on my 1700. In trying to see if my pto sliding coupler engages properly, I can with the engine off, clutch and engage the pto, I then with engine off can turn by hand PTO final shaft in one direction ( CCW) and not the other way. in that fix, without anything attached to pto I can then turn the engine on without any issues with pto and see it turn. My suggestion is for diagnostics and visual clues only.
JC,
Hey....had to go out of town on business.....
I'm back and going to take the tractor by the shop tomorrow
They seem to think that the clutch is stuck.
Apparently this happens often enough that ford put a small lever on the back side of the clutch pedal, so when stored for lenghts of time the clutch can be locked in the disengaged position.
The service manual costs $200 plus dollars....It is going to be cheaper to let them diagnose the problem.....go figure
the PTO will engage with no load on it......it will also engage under load as long as the end shaft is spinning at a reasonable speed.
2017 Ford F-450 XL (A50123)
2017 Ford F-450 XL...
2 pair -st205/75r15 radial trailer tires (A53421)
2 pair...
2001 JOHN DEERE 310G BACKHOE (A52705)
2001 JOHN DEERE...
MASSEY FERGUSON 492 TRACTOR (A51406)
MASSEY FERGUSON...
2011 FONTAINE 48 FOOT STEPDECK (A53843)
2011 FONTAINE 48...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
