Heywood Jannockitov
Platinum Member
- Joined
- Jan 9, 2008
- Messages
- 842
- Tractor
- Deere 27d, JD 5425 cab, JD F620, JD XUV 850D, Case 580 SE, IH 484
...but after owning 2 3/4 tons and 3 1 ton SRW trucks I can tell you the 3/4 tons were a waste of money for me when I found out like Builder did you can get a 1 ton SRW for $500 to $600 more than a 3/4 ton and have 1000# to 1500# more payload with the same size truck. When it comes to towing 12,000# or more the 3/4 tons take a hurting but the 1 tons SRW still feels stable and safe.
Chris
I pretty much agree with the 1 ton SRW sentiments expressed by Builder and MU-300 pilot. I don't think 3/4 tons are useless though. Although 1 ton SRW Dodges weren't available in 1995 when I got my last new truck, I essentially turned it into a 1 ton (or better) by adding Firestone air helper springs. I would start to worry about stability and tire loading though if towing up in the range they are talking about. That's a lot of weight on only 2 rear tires.
If you ask me, it is 1/2 ton pickups that are useless. Yooperdave's photo validates this. For a vehicle the size of a full-size pickup, it should START with a payload of 1500-2000 lbs. A 1/2 ton is great if you want to carry a full load of ping pong balls or rigid styrofoam insulation. The manufacturers have finessed the suspensions to the point that even 1 ton duallies ride pretty good.
A japanese kei mini truck will support almost as much as a full size 1/2 ton.
