new rear remotes, 3 PH won't raise
   / new rear remotes, 3 PH won't raise
Thanks guys, The valve I have is a
Badestnost Model# A1A1SKZ!
I will post a picture in a little while. Thanks again for all your help.
   / new rear remotes, 3 PH won't raise #12
Not sure what you mean by "PB sleeve"?
A PB sleeve is designed to block the fluid from the cyl ports and pass the pump flow through the PB fitting for use downstream. If you don't have the PB fitting, then go to the valve manufacture and find the correct PB sleeve.
   / new rear remotes, 3 PH won't raise #13
Looks like the valve was made in Bulgaria. There is a contact email.
Badestnost JSCo
   / new rear remotes, 3 PH won't raise #14
Badestnost JSCo
They're also known as high pressure carry over adapters, most European companies refer to them as that.
Sean
Thanks guys, I will see if I can get a PB sleeve, I'll let you know how things go
   / new rear remotes, 3 PH won't raise #17
A picture would sure help, on most valves you can't even hook up the PB hose if the sleeve is not in place since the hose actually connects to the sleeve.
   / new rear remotes, 3 PH won't raise #18
I think the threads into my valve were #8 ORB, I added the adjustable elbow and converted to #6 JIC for the hose end.
Am I correct in saying that the plug remains in place (where the PB sleeve goes) if the valve is the last one in the circuit? It makes sense that way to me, but according to the wife, my logic is fundamentally flawed at the best of times.
Sean
   / new rear remotes, 3 PH won't raise #19
Sean
It really depends on the valve...and not being familiar with the Badestnost brand I can't say, that's why a picture would be nice.
2013 Ford Transit Connect Van (A52377)
2013 Ford Transit...
2014 Chevrolet Equinox SUV (A53424)
2014 Chevrolet...
HYDRAULIC PTOS (A53843)
HYDRAULIC PTOS...
2008 Caterpillar 262C Skid Steer (A52377)
2008 Caterpillar...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A53473)
2020 Westfield MKX...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
