New shop build, beginning stages with questions
   / New shop build, beginning stages with questions
I'm with you so far, I only had so big of a piece of steel on hand... it's spanning 3 joists (4x4's so a little sturdier in some ways) and lag bolted at the front and has threaded rod at the rear through the joists and in the center it's through the top plate of the wall at the junction.
I'm going to run with it for now but will likely add a support going back further in the middle, might be just an eye bolt and cable...
   / New shop build, beginning stages with questions #282
Any chance of running a metal pipe up through the center of the hoist, maybe up to 7' high, and then cable from the top end back to your outside wall post as a top anchor?
That's the type of thing that's been running through my mind lately and would be functionally cleaner than lower mounted cables... even if I put a 2x6 across the angular supports (probably 5' above the crane) to catch the top of a post welded to the top of the pivot it would help a lot... I'm not planning on testing any limits of the thing, the heaviest engine block I plan on dragging up there for now is only about 500 pounds and I'm not in a rush on that... for the smaller bulky things to get out of my way I'm not worried at all up to 300 pounds or so.
2020 Ford F-150 XLT (A44501)
2020 Ford F-150...
2007 BBB F40 STATION MANIFOLD TRAILER (A45333)
2007 BBB F40...
2015 Ford Explorer AWD SUV (A44572)
2015 Ford Explorer...
Kubota RTV 900 (A44502)
Kubota RTV 900...
1500 Gal Poly Leg Tank (A44502)
1500 Gal Poly Leg...
2014 Ford F-450 Liftmoore 5000W Mechanics Crane Truck (A44571)
2014 Ford F-450...
