New to me 1802D.. Looking for information.
   / New to me 1802D.. Looking for information. #11
I've never seen a YMxx01, YMxx02, YMxx10, or YMxx20 without a water pump, although the YM1110 is a model I have not yet sold, and it may have the older style engine. Certainly the smaller YMxx00's do not have pumps. We mainly sell 3 and 4 cylinder Yanmars, so I am a little out of my area of expertise when speeking of the 2-cylinder models. Good comment about the percentage of anti-freeze. If it is too high, the collant will not cycle properly.
   / New to me 1802D.. Looking for information. #12
I have only been lucky enough to play on the 2 cyl models... Maybee eventually I'll get another one.. perhaps a 3cyl... I'll have to get used to the smoother running engine of the 3cyls.. instead of the yammerhammer of the 2cyl's.
Soundguy
<font color=blue>I've never seen a YMxx01, YMxx02, YMxx10, or YMxx20 without a water pump, although the YM1110 is a model I have not yet sold, and it may have the older style engine. Certainly the smaller YMxx00's do not have pumps. We mainly sell 3 and 4 cylinder Yanmars, so I am a little out of my area of expertise when speeking of the 2-cylinder models. Good comment about the percentage of anti-freeze. If it is too high, the collant will not cycle properly.
   / New to me 1802D.. Looking for information. #13
There is nothing at all wrong with the 2-cylinders, they just don't do well in my California market. I have an FX42D with a 4-cylinder turbo diesel...talk about smooth!!!!!
My 1802D does have a water pump. Well at least it looks like a water pump to me.. Does anyone know what the napa cross refrence filter for this tractor is? The guy I bought it from told me that it used the same filter as the JD750. I picked one up at napa today. It looks to be pretty close but would like confirmation before I take the old one off and drain the oil. Also where the heck is the drain plug on these things?
Thanks,
Chadd
   / New to me 1802D.. Looking for information. #15
Most of the 2cyl have water pumps.
   / New to me 1802D.. Looking for information. #16
Chadd, the oil filters that I use are the fram PH3593A
for the oil.
the drain plug is under the engine on the side of the oil pan
Yes the 1820 has a water pump
You can buy a manual from Leonard Sheaffer.
Ernie
   / New to me 1802D.. Looking for information. #17
You will like the tractor I also have a 1802D great little tractor , the only thing I have chage is to put truf(ans) tire on the back.. wish I had the loader
   / New to me 1802D.. Looking for information. #18
Many dealers out there, including myself and a couple others in this thread handle the Koyker loaders. Buy yourself one for Christmas, make it red, put a bow on it! You can then haul all the rest of the presents in the bucket, bring up firewood, keep the driveway clear....
   / New to me 1802D.. Looking for information. #19
To my knowledge, the YM1110/YM1101 is the only YMxx01/YMxx10/YMxx02/YMxx20 that does not have a water pump. The YM1110, YM1101, and the YM2210 are the only tractors of the YMxx01/YMxx10 with 2 cylinder engines. The 2210 does have a water pump.
Of the older YMxx00 series of tractors (mostly 2 cyl), the YM2000 is the smallest with a water pump. Incidentally, I think the YM2000 water pump will install on a YM1700, but don't take my word for it - check into it carefully before trying as water pumps are really expensive.
   / New to me 1802D.. Looking for information. #20
Gbirky,
I can answer the question about installing a water pump on a YM1700 because I have done it. The YM2000 water pump will work on a YM1700, however, you do need the pump mount, 2 new hoses, and a few misc. parts (bolts, washers, clamps, etc.). Takes about 2 hours, not really all that hard.
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
. (A58216)
. (A58216)
Vivohome Single Stage Vacuum Pump, Model VB150, 1/3 HP, 110 Volt, Vivohome Gage Set (A59076)
Vivohome Single...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
Hatz Diesel 6 Inch Water Pump (A57453)
Hatz Diesel 6 Inch...
