New to me Kubota ZD326 ZTR Mower: How did I do?
   / New to me Kubota ZD326 ZTR Mower: How did I do? #21
Yea, I was thinking of doing the exact same thing. My right tank is showing empty when I just put five gallons of SC TN red fuel diesel in it; yea it's forked. Why they didn't tie they into together to begin with is a mystery.
How hard was it to do it?
Not to bad. You need two Ts because of the return line. The biggest issue I had was getting the extra plumbing crammed back in there. The Ts have to stay in that area, because that's where the fuel lines end...at the transfer switch. Once done, that 3 position transfer switch is ON-OFF-OFF.
The light comes on when that tank is 1/2 full....verifiable when/if you rearrange the lines like I did. Light starts flickering, gauge will read 1/2 full.
   / New to me Kubota ZD326 ZTR Mower: How did I do? #22
Plugged both tanks to a T fitting, then took the T to the transfer switch. Made a short blocked hosed to attach to the other side of the transfer switch. You don't touch the transfer switch after that. You ought to do it....wayyyyy better that way.
Thanks. Will have to look at the area your referring to (switch area) and then try and grasp the process/concept. I have to have pictures or drawings or actually look myself which I cn't do now since I'm away from machine. Two brass Ts and do you know size?
   / New to me Kubota ZD326 ZTR Mower: How did I do? #23
Not off hand. I just pulled one of the lines, stuck a bolt into it....then measured the fitting on the transfer switch. Auto parts store would have them.
   / New to me Kubota ZD326 ZTR Mower: How did I do? #24
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
BETTER BUILT FUEL CELL (A58214)
BETTER BUILT FUEL...
206707 (A58375)
206707 (A58375)
2008 CMTL 19ft Homemade Travel Trailer (A55973)
2008 CMTL 19ft...
2019 Harley Davidson (A56859)
2019 Harley...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
