New toothbar, bucket hooks and oops
   / New toothbar, bucket hooks and oops #1
notamustang
So Cal
BX 2230
Fab-co 23 series adapters and teeth.
Bucket hooks 5/16 slip center and 5/16 grabs on the outside edge.
3PH oops /forums/images/graemlins/frown.gif
   / New toothbar, bucket hooks and oops #3
And 'what' are we looking at in the 'oops' pic? /forums/images/graemlins/confused.gif
This piece that has been fixed /forums/images/graemlins/grin.gif
Its the stabilizer for the 3PH, the u-bolt is at a roghly 75 degree angle. The weld on the bolt broke free on one side.
I should also add what everyone with a toothbar says, GAWD THIS IS GREAT !!! I posted somewhere elese that I was happy but shoud have gone with a 6 tooth bar. I was contemplating adding 4 more teeth between but that bar is so heavy now I woont be able to pick anything up. I am re-thinking how bullit proof my grapple is going to be. That is a lot of extra weight on the front of the BX. I figure something out.
Steven
   / New toothbar, bucket hooks and oops #5
Nice looking bar and hooks!
Did you determine if the stabilizer was a factory failure or if you did something to stress it too much?
Thanks HomeBrew2. It was the loose nut, the behind the wheel /forums/images/graemlins/crazy.gif
The area I was working was a little tight and I was dragging the box blade on one corner. The soil is similar to dragging across chunks of concrete. The clay with rocks inbeded make a very stable surface /forums/images/graemlins/frown.gif. On a side note the GearMore box blade is fine. /forums/images/graemlins/grin.gif
Attached is a better pick of the hooks. I found while cutting the hooks down to use my grinder with a cutting wheel as opposed to my chop saw. I tried tack wellding one of the hooks to a piece of flat bar and then cutting with the chop saw, I glazed the wheel /forums/images/graemlins/frown.gif. The mount is just a piece of 2x angle
   / New toothbar, bucket hooks and oops #7
Thanks, I just like to keep track of how stuff gets broken cuz I know whatever somebody else breaks, I'll be breaking it too sooner or later /forums/images/graemlins/wink.gif
Re: chopsaw glazing. Most folks probably know this trick but, for those that don't, I wanted to pass it along: I keep a bench grinder dressing tool on hand whenever using the chopsaw to keep the wheel clean. On long thick cuts, I even dress it while cutting. It's amazing how well it works.
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2000 JOHN DEERE 444H WHEEL LOADER (A52705)
2000 JOHN DEERE...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
