New toothbar, bucket hooks and oops
   / New toothbar, bucket hooks and oops #1
notamustang
So Cal
BX 2230
Fab-co 23 series adapters and teeth.
Bucket hooks 5/16 slip center and 5/16 grabs on the outside edge.
3PH oops /forums/images/graemlins/frown.gif
   / New toothbar, bucket hooks and oops #3
And 'what' are we looking at in the 'oops' pic? /forums/images/graemlins/confused.gif
This piece that has been fixed /forums/images/graemlins/grin.gif
Its the stabilizer for the 3PH, the u-bolt is at a roghly 75 degree angle. The weld on the bolt broke free on one side.
I should also add what everyone with a toothbar says, GAWD THIS IS GREAT !!! I posted somewhere elese that I was happy but shoud have gone with a 6 tooth bar. I was contemplating adding 4 more teeth between but that bar is so heavy now I woont be able to pick anything up. I am re-thinking how bullit proof my grapple is going to be. That is a lot of extra weight on the front of the BX. I figure something out.
Steven
   / New toothbar, bucket hooks and oops #5
Nice looking bar and hooks!
Did you determine if the stabilizer was a factory failure or if you did something to stress it too much?
Thanks HomeBrew2. It was the loose nut, the behind the wheel /forums/images/graemlins/crazy.gif
The area I was working was a little tight and I was dragging the box blade on one corner. The soil is similar to dragging across chunks of concrete. The clay with rocks inbeded make a very stable surface /forums/images/graemlins/frown.gif. On a side note the GearMore box blade is fine. /forums/images/graemlins/grin.gif
Attached is a better pick of the hooks. I found while cutting the hooks down to use my grinder with a cutting wheel as opposed to my chop saw. I tried tack wellding one of the hooks to a piece of flat bar and then cutting with the chop saw, I glazed the wheel /forums/images/graemlins/frown.gif. The mount is just a piece of 2x angle
   / New toothbar, bucket hooks and oops #7
Thanks, I just like to keep track of how stuff gets broken cuz I know whatever somebody else breaks, I'll be breaking it too sooner or later /forums/images/graemlins/wink.gif
Re: chopsaw glazing. Most folks probably know this trick but, for those that don't, I wanted to pass it along: I keep a bench grinder dressing tool on hand whenever using the chopsaw to keep the wheel clean. On long thick cuts, I even dress it while cutting. It's amazing how well it works.
2008 New Holland B110 MFWD Loader Backhoe (A55218)
2008 New Holland...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2017 FORD F150 REG CAB LONG BED 4X4 (A54313)
2017 FORD F150 REG...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
