New tractor - recommendations on 3PH use
   / New tractor - recommendations on 3PH use
A PTO-powered air compressor? Never see one of those. The boom pole is a good idea I'd never considered. I'll probably need one of those. Thanks.
I have quite a few 3 pt attachments so the top 5 would be (in order of frequency of use)
1. landscape rake for the driveway.
2. 7' rear finish mower for fields and pathways.
3. Hay rake (I first ran all my hay equipment with 22 hp).
4. Post hole digger for fence maintenance.
5. Box blade for the road (I just added a hydraulic top link ).
Others include:
rototiller for gardens and deep dig in the gravel driveway.
1/3 yard cement mixer.
trailer hitch.
boom pole for yanking things up in the air (like lawn mowers for blade maintenance.
pto generator (when you need remote power, or just house power after a storm).
work platform for carrying tools, shovels, saws, fuel out to the required areas.
air compressor for taking air out to where you need it.
I use a self powered chipper behind a golf car for bush wacking and limb disposal and a front blade for snow removal. My broke neck eliminates the rear snow blower. I wish I had a post driver, though. That's the next "Be on the lookout for" item. The concept of pounding a new or replacement fence post along side a broken one is just too fascinating for me to live without.
   / New tractor - recommendations on 3PH use #12
I've got a new JD 3032e with an FEL, 25 PTO HP, and dual rear hydraulics and am looking for recommendations on how best to use my Cat 1 3PH. Here's what I anticipate I may be doing with it:
- Grading/crowning my gravel driveway (I've got a single blade on loan from the dealer now that I'm trying out).
- Hauling firewood. I like the idea of storing firewood on pallets and then using the FEL or 3PH to move the pallets to near where we burn.
- Maybe splitting firewood if it makes more sense than using a stand-alone splitter
- Mixing concrete (I already have a stand-alone mixer but I might sell to buy a PTO-driven model)
- Post hole digging (probably with a rented skid-steer unit if that makes sense.
- Possibly chipping/shredding (rented skid-steer attachment if available)
- Mowing trails through the brush around our property
- Towing trailers around the place
- Maybe stump grinding with a rented skid-steer unit
- Maybe breaking rock if I have the hydraulic power for it (about 9.3 GPH)
I'd like to buy implements as I find deals and rent the ones I'll use less often. I'd like to rent skid-steer attachments if they will work as they're readily available nearby. I also have a friend who has a PowerTrac so I may have access to his attachments (in trade). I realize they use a different mount.
I'm already convinced I want some sort of quick-attach for the 3PH but I'm just not sure what kind. There's JD iMatch, aftermarket units, skid-steer types, Pat's Easy Change, etc. I'd much prefer to buy American-made.
I've used heavy equipment of one sort or another for many years but my experience with 3PHs is limited having only used a rear blade. I've used Bush Hogs and harrows but I just drove; I didn't set up the 3PH. I can fabricated and have a welder, cutting torch, etc. so I"m happy to modify or build something. Given this laundry-list of needs and resources what's the setup that makes the most sense for me?
If I'm re-hashing something that's been covered already, sorry about that. I did some searches but didn't come up with what seemed pertinent. Links to other posts are welcome.
Thanks in advance.
Andy
I have a skid steer adapter for the ML250 FEL on my 2008 Mahindra 5525. Makes removing and reattaching the bucket easier so I can use skid-steer implements. I made a skid steer compatible hay bale accumulator/squeeze earlier this year. I'll make skid steer compatible forks later. I suppose you could rig up (or buy) some kind of skid steer adapter for your 3pt hitch. Shouldn't be too difficult or expensive.
9.3gpm flow from your tractor hydraulics is on the low side for typical store-bought (or rented) skid steer implements. There are pto-powered hydraulic units that can give you more flow for these implements---for example to power a hydraulic post hole digger that attaches to the FEL.
   / New tractor - recommendations on 3PH use #13
I looked at a splitter for the 3 ph, but I didn't like the idea of the tractor idling all day. I got an electric splitter from Home Depot, for about $350. Not manly, I know... but you can have a civilized conversation while you're splitting wood, you can use it IN the house to make kindling in the dead of winter. After splitting 8 cords of wood with it, maybe a dozen or two sticks needed the chainsaw to split them once, then the Ryobi did the rest. A good buy for my money.
Chilly
I already have gas splitter but an electric one interests me. Does the motor run constantly or switch on and off with each split?
Chilly
   / New tractor - recommendations on 3PH use #15
Mine is a Ryobi, sold through Home Depot. Very similar to others, a few minor changes in operating levers, wheel kits, etc.
It only runs when you actually are splitting. Mine was equipped with both a pushbutton and a lever, the idea being that if you had to use both hands to operate the splitter, you couldn't get either of them anywhere they could get injured. Great idea if you're a lawyer, not so practical when you're splitting wood. Mine now has a spring holding the lever depressed, you push the button to start the motor, leaving a hand free to hold the wood in place until it's between the ram and the knife. Common sense tells you where to keep your hands out of !
I had some pretty serious doubts that it would do the job, even after reading the reviews. I'm a believer now. There ARE pieces it won't split, no question, but a chainsaw is never far away for those.
I was going to build a gas splitter, then discovered it was cheaper to buy one.
If I ever build a splitter, it'll be a 220 volt motor with a two stage hydraulic pump, I really like the convenience of not having a gas engine running while I'm working. No fumes, no gas cans, no running OUT of gas !,
easy to store, etc. I should also add that all my wood comes to within easy reach of my garage before it's split, so an extension cord is always an option. It sits on a folding table when running, much more comfortable working height.
A friend of mine in Sweden has a 220 volt model, I'm pretty impressed with what I've seen of that one, I think the pump does run full-time on his.
Chilly
I have a lot of same preferences that you do with respect to fumes, noise, etc. I'm going to look into electric splitters. Thanks for the info.
Chilly
   / New tractor - recommendations on 3PH use #17
My signature shows the 3 point attachments I have but the one I use the most is the Combo Hitch and accessories from OMNI Mfg
ARI-Hetra 15,000lbs Auto Lift (A56860)
ARI-Hetra...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
2002 Allmand Night-Lite Pro Towable Light Tower (A56857)
2002 Allmand...
KSI Conveyor (A56436)
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
Pallet of Stihl Blowers (A56860)
Pallet of Stihl...
