New Tractor, Tractor Newbie, Lots of Questions...
   / New Tractor, Tractor Newbie, Lots of Questions... #11
Regarding hills, I think I qualify as owning a few of those, some steep enough that only the little garden tractors go on because the bigger toys would flip over backwards . . . so I've puckered a few times in a few places on my land and thankfully have never rolled.
But here is my take on it. <font color="red"> WEAR YOUR SEATBELT, keep your arms tucked in, and let the ROPS do its job. </font>
We were running some electical lines down to my pool house and pool, which sits 100 feet from the house, much of that distance is downhill. The senior electrician strapped an apprentice into the cage of a "Ditch Witch" and pointed him in the general direction of where we needed to end up . . . his parting words to the newbie were: "WHEN it starts to roll on you, just stay inside the cage!"
I trust my ROPS but I don't want to test it. As for building a roll cage, that is a PROFESSIONAL project and you run into some problems because if you don't built it strong enough the front of the cage could collapse down on you. And you run into the problem of connecting it up to the ROPS. Drilling or welding to the ROPS would likely void its warrenty as it would potentially damage the structural integrity. You'd probably want to clamp the roll cage to the ROPS and then weld the front connections of the roll cage directly to the frame of the tractor.
I think wheel weights or fluid loading the tiress might be a very smart idea for you because it keeps the center of gravity low. On my B2910 I have iron plate under the frame to pull the C.O.G. down. On my NH TC24D I have EZ-Weights installed inside the wheels. On my Cub Cadet I have factory wheel weights on the rears. I prefer iron to fluid becuase if you get a flat you don't get a leak, but many prefer fluid fills and it can lower the C.O.G. lower than iron weight. If you want to see what EZ weights are, at the bottome of this post is a link to the custom weights I put on the front wheels of my NH TC24D to prevent my tractor from popping wheelies and tipping over backwards . . .
<font color="red"> Do NOT operate the F.E.L. without rear weights, filled tires, wheel weights, or the backhoe attached. A heavy bucket combined with a light rear end will flip your tractor (and I have a story about a very close call I had about a month ago . . . it is posted somewhere on this board) </font> /forums/images/graemlins/blush.gif
EZ Weights on the Front Wheels of a Class I Boomer
   / New Tractor, Tractor Newbie, Lots of Questions... #12
HB --
Looks like you already have lots of good answers, but here is one more: Read your operator's manual, then read it again and study it carfully. Most of the answers you are looking for can be found therein. In the beginning it is helpful to look through it frequently, as there is a lot to remember, and the manual is not all that well organized. (BH information is located in at least three different places, for example!) When I got my '23 I drove it around a bit, but resisted the temptation to do much with it. That night I studied the manual, and the next day I put about five hours on it.
Congrats on being focused on safety and proper operation -- that's a key to getting the most from your machine and living to tell about it. Maybe we could say that there are old tractor operators and bold tractor operators, but ... /forums/images/graemlins/confused.gif
/forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif
One thing I don't think anyone has mentioned yet, but I believe is in the manual: when going up hills, drive in reverse if at all possible. (Now, how ya gonna do contour plowing like that?)
Welcome to the BX23 club!
/forums/images/graemlins/tongue.gif
Re: New Tractor, Tractor Newbie, Lots of Questions
</font><font color="blue" class="small">( <font color="blue"> 1. Is there a "Tractors 101" book available anywhere? I'm interested in safety, of course, but also in how to use the various implements, especially the backhoe. </font>
There is indeed such a book... Its called "Operating Techniques for the Tractor-Loader-Backhoe" by Gary Ober. I got mine from www.equiptrain.com. The book is written in a very simple style (some might feel its a little too simple) but it does contain lots on useful safety information and techniques for operating. My guess is that it might be intended as a textbook for a training course (since it has practice questions at the end of each chapter) but I found it to be a good primer on operating and still occasionally refer back to it from time to time.)</font>
I have one on the way. Thanks for the referral!
Hog
   / New Tractor, Tractor Newbie, Lots of Questions... #14
good advice. what i sugesst guys do is read the manuel, then read it again then read it while they are with the or sitting on the machine, nothing like reading and looking at it at the same time. i do this with many things.
   / New Tractor, Tractor Newbie, Lots of Questions... #15
This book is written for larger tractors but much is applicable
to the little ones.
I found (still find) it very useful and enjoyable and would
highly recommend it.
Helps you in the Hope-I-Don't-Look-Like-Too-Much-Of-A-Goof-When-
The-Neighbors-Are-Watching department!
/forums/images/graemlins/smile.gif<font color="blue">D</font><font color="orange">E</font> <font color="green">L</font>/forums/images/graemlins/smile.gif
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
John Deere 1025R (A53317)
John Deere 1025R...
2007 FREIGHTLINER COLUMBIA TANDEM AXLE SLEEPER (A59575)
2007 FREIGHTLINER...
5' MOWER (A52706)
5' MOWER (A52706)
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
