New Utility Trailer + Wimpy Truck
   / New Utility Trailer + Wimpy Truck #61
Thanks for all the advice fellas. I知 going to focus on getting a single axle 12-14ft trailer in the 1000-1200lb range with a 3000lb GVWR that can be legally and safely towed with my Ridgeline.
The laws in Virginia state that any trailer over 3000lbs requires brakes. And secondly, if a trailer has brakes it requires an annual state inspection. Going to keep it simple for now....low cost and free of state inspections.
Lot to be said for keeping it simple..... a very smart mechanic friend of mine stays with single axle basic trailers for himself, for similar reasons..... AND, he is someone who could easily/legally certify a larger trailer himself.
Spend time on here and it's easy to get talked into an F550 and a tri-axle float :D , but IMO there is a lot of utility in even a basic smaller trailer..... sometimes household items are more bulky than heavy, and any trailer adds flexibility that you don't have otherwise.
One thing I like about trailers for dump runs is if it takes me multiple days (an hour here and there) to get brush cutting or whatever done, I just pile things in as I go. With a regularly used truck, I don't like having trash piled up in it, so for how I use both, the trailer saves me dump runs... :2cents:
OK... I'll add 4cents...... a lot of low-cost trailer tires (ST class) are pretty sketchy, so keep a close eye on them, and keep them inflated to Max pressure, or close to that. If you can, park the trailer on cement or pavement for storage - if not, park the tires on 2x6 or larger PTreated boards. Many tires don't do well parked on dirt - service life gets shortened dramatically.
Rgds, D.
2015 Ford F-350 Cab and Chassis Truck (A56858)
2015 Ford F-350...
UNUSED JCT HYD POST/TREE PULLER (A58376)
UNUSED JCT HYD...
New/Unused Quick Attach Bale Spear (A57453)
New/Unused Quick...
Phillips 3003A (A57148)
Phillips 3003A...
CAT930K (A58214)
CAT930K (A58214)
2006 Sterling Single Axle Road Tractor (A55272)
2006 Sterling...
